brakes make retarded sounds every now and then :wtf:
pronounced tech
so there have been a few times where ive had to make tight turns w/in parking lots and have heard strange noises when ive had to use my brakes
sounds like a walrus for a quick second or two. its only happened about 3x's in the past month and its always at low speeds and when my wheels are turned, not straight
any ideas??
any ideas??
you may have a rock stuck in there (you have some thin metal plates that squeal to give you notice your brakes are getting low...there's room for a rock to get stuck in there)...we had a noise when it was new (we drove on brand new blacktop and I figure some got into the caliper)
you may want to just pop off the 2 front wheels (if that's where the sound is definitely coming from) and pop the calipers back as if to just simply change pads...remove the pads and check the metal backing (that plate can also be slightly bent upon installation making them drag on the rotor)...also inspect the rotors for something dragging on it (you'll see gouged lines - small ones aren't a big deal)
