EZ to Install fogs on TSX?
Looking to add the OEM fogs to my TSX. Has anyone installed them before? Is it worth the extra $150 to have the dealer do it or can I do it myself? Do the OEMs come with a dash switch? Has anyone seen non-OEMs that look the same? Thanks!
Anyone can install it themselves, the question is do you feel confident enough to install them. I installed my fogs myself and found it very simple to do.
The hardest part I would think is to pass the wire through the firewall.
Originally Posted by UtahTSX
Does anyone know if the TSX is pre-wired for fogs? I haven't taken a close look yet.
Not it's pre wired you have to change the Stalk that is on the factory steering wheel column thing. When you order the Fog's if you haven't received them yet inside it comes with a new stalk that now supports the foglights. IMO it gives it the cleaner look without having to cut a hole on the dash or anywhere else.
