auto-cross/club
Old Jan 6, 2006 | 08:48 AM
mtbprelude's Avatar
mtbprelude
RIGHT Wheel Drive!!!!
Originally Posted by Solracer
I would thOroughly disagree with that statement. Racing against the clock on a track by yourself and trying to win, is completely different that racing against 30 or more other cars at the same time on the same track for over 20 mins or more.
dOOd, no way, DRAG RACING is the most difficult motorsport. I mean dumping the clutch as the light turns green, then shifting when the big yellow light on the tach tells me to, and trying really hard not to yank the steering wheel into the other lane.... [/sarcasm]
The margin for error in AX is razor thin:
The course (where turns/maneuvers are) is NEVER the same weekend to weekend, there is no practice, no pre-drives, no qualifying, all you can do is walk the course, You can't "see" your competitors on course or track in AX., and you have 3 shots to get it done.
Its a 99% mental sort of motorsport. That's all Mike was trying to say, I don't think he was trying to start an e-pissing contest.
Old Jan 6, 2006 | 10:07 AM
Solracer's Avatar
Solracer
NASA-VA Hyper-Announcer
If you do not think this applies to road racing also, then I do not know what to say, add all the above, and then add 30 or more of you closets friends racing right next to you.
Each discipline has its own pitfalls and I would rank road racing at the top, the auto-x right underneath it. I drive VIR about 6 times a year and each time I am surprised how different the track is every visit.. If you are only getting three runs at your auto-x you need a different club We get 5 to 6 runs every event with around 130 cars.
Old Jan 9, 2006 | 06:50 PM
mikesta21's Avatar
mikesta21
93preludesi
damn i want to do that, but what is required to get your car up to spec.
i looked on scca before, but i read about roll cages and stuff im not prepared to buy.
Old Jan 10, 2006 | 04:57 AM
Solracer's Avatar
Solracer
To do what? To autocross you do not need any special saftey stuff except a helmut. To get on track you can do an HPDE which has simular requirements.
Old Jan 12, 2006 | 11:07 AM
mtbprelude's Avatar
mtbprelude
Re-read what I said. I realize you have a preference for road racing but it is a much different discipline. There is not 1 greater...
In road racing the margin for error is thin, but it is not as thin as that in an Autocross, you miss an apex by 6 inches on a road course and unless he's out to wreck you, your competition can't pass you. You miss your apex by 6 inches in an Autocross and you plummet positions.
Do you know where each of your 30 'friends' is on track, in relation to you? Absolutely, and you can maneuver your car to a) pass them, b) block them.
Do the turns at VIR move? Does a turn disappear? No. The track surface is the never the same, though it could be argued that for autox from run to run the surface also changes....
Autocross doesn't have the strategy of having to block, or pass, it certainly doesn't have the endurance factor(good thing too, because there are some llllaaaaaarrrrrggggeeee folks that AX), road racing requires much more durable equipment, more stringent safety measures due to a high risk factor associated with high speed and generally any car can autocross provided its safe for street use, so its much cheaper.
3 runs per course times 2 courses is all you get at the top levels of Autocross: Divisionals, National Tours, and Nationals. Sorta ratchets up the mental pressure. Locally, its another story...
Old Jan 13, 2006 | 08:22 AM
mr.crx's Avatar
mr.crx
ok no reason to argue about what sport is better. they are both tuff just a matter of preference. it doesnt make you any better then the next
Old Jan 13, 2006 | 08:54 AM
MiataMania's Avatar
MiataMania
Go Kart Driver
He is right, they are both hard, and require different skills from both driver and car alike...word to the miata driver, and thanks for the welcome mr.
To answer the original question, does honda offer racing parts for racers? I'm a part of MazdaSpeed Racing program so I can buy competition and stock parts for a discount from them...its just a matter of having proof you race.
