2nd Annual Hondafest day @ Englishtown, NJ
Old Feb 17, 2004 | 06:39 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
Default 2nd Annual Hondafest day @ Englishtown, NJ
What: 2nd Annual Honda Day and [...] Raceday
Where: Englishtown's Raceway Park
Who: You!
When: Saturday March 27th, 2004
We were very encouraged by everyones comments about the first event, so we are hoping to blow that first event out of the water in terms of attendance and enjoyment for the racers and spectators.
Where: Englishtown, NJ - Raceway Park
Address to use for directions: 230 Pension Road Englishtown, NJ 07726-8462
Time: Gates open at 9am, it stops when there is no more racing left to do
***1/4 mile bracket and heads up drag racing
***Autocross open to all Hondas and Acuras
***BFGoodrich Super Challenge for best combined Drag & Autocross car- DOT radials only!
***Classes for all drivers and states of tune
***Special Manufacturer and Honda Tuner Midway
***Lots of Trophies, Cash, and Prizes to be handed out
This is the biggest Raceway Park one make event ever. This is event of the year for Honda/Acura owners. Find out how your Honda/Acura stacks up against the best of the rest!
**********UPDATED INFO ON DRAG**********
2 Bracket Classes:
*B1 - 15.00 & Slower
*B2 - 14.99 & Quicker
2 Heads Up Classes:
*All Motor Class - All cars in All Motor must meet noise and safety regulations. Transplants, slicks, lexan, and fiberglass allowed.
*Power Adder Class - All cars in Power Adder must meet noise and safety regulations. Slicks, lexan, and fiberglass allowed.
Trophies and prizes awarded to Winner and Runner-up in each of the drag racing classes.
*All cars must be street muffled. (All cars must meet noise regulations for Saturday Street muffled racing. For more information go to http://www.racewaypark.com)
**********UPDATED INFO ON AUTOCROSS**********
The Super Challenge will consist of 3 time trials at the quarter mile dragstrip and 3 time runs at the autocross course. The combination of the two events will determine the 1st, 2nd, 3rd, and 4th place finishers. Your score will be determined by how well you perform in each of the events. For example if you finish in first place in the drag racing portion and in third place in the autocross portion you will have a total of 4 points (2 points will be the best possible score). The competitor with the least amount of points at the end of the day will win the event. The Challenge is open to all Honda and Acura “street type vehicles”.
Autocross:
Open to all Honda and Acura automobiles. Trophies awarded to 1st, 2nd, and 3rd places.
Class 1:
Class 2: Acura NSX
Class 3: Acura Integra Type R, Honda S2000*
Class 4: Acura RSX-S, TL-S, CL-S, CL-S 6spd*, Integra GSR, Honda 03 Accord-6cyl, Prelude VTEC, Prelude SH*
Class 5: Acura Integra (non-VTEC), CL V6, TL, RSX*, Honda Civic SOHC-VTEC, Civic DOHC-VTEC*, Accord V6, 92-96 Prelude (non-VTEC)
Class 6: Acura 2.2/2.3 CL, Honda Civic Non-VTEC*, Accord 4-cyl, Prelude 83-90, HF series
*5 points automatically assessed
Modifications and Points Assesments:
Modification points are added to each car in class. If your car equals 11 points you will be bumped up one class. There is no limit – a car with high level of modifications might move up several classes.
NOTE: Jack, spare tire, trunk carpeting, and tools are free
11 thru 23 points – Up ONE Class
24 thru 36 points – Up TWO Classes
37 thru 49 points - Up THREE Classes
50 thru 75 points – Up FOUR Classes
over 76 points – Class 1
Wheels/Tires:
---All SUPER CHALLENGE Contestants must be on DOT radials!---
1. DOT – approved tires with treadwear 80 and below (5)
2. Non-DOT approved tires (8)
3. Wheels and tires extend beyond original bodywork (2)
4. Plus size wheels (Plus one, two, or three) (2)
Weight Reduction:
1. Replacement non-adjustable seat (2)
2. Gutted interior Front (3)
3. Gutted interior Rear (anything behind front seats removed) (2)
4. Lightweight hood (1)
5. Lightweight Fenders (2)
6. Lexan/Plexi glass windows (4)
7. Remove power steering (2)
Engine/Drivetrain:
1. Engine swap (11)
2. Increased displacement (not to be added to Engine Swap) (5)
3. Non-OEM forced induction (11)
4. Air intake system (2)
5. Cat back exhaust (2)
6. Header (3)
7. SFC/VTEC controller/Performance chip for NA engine (4)
8. Performance Chip/Boost controller for Turbo engine (6)
9. Programmable electronics/fuel injection system (Includes boost/fuel-timing map) (8)
10. Replacement pulleys (1)
11. Lightweight Flywheel (1)
12. Other internal engine modifications (4)
13. Ring and pinion change (2)
14. Add/modify limited slip (3)
Suspension/Brakes:
1. Performance non-adjustable shocks (2)
2. Adjustable shocks (4)
3. Performance/Lowering Springs (2)
4. Full coil-over suspension (included adjustable spring perch/spring/shock) (8)
5. Changed/Added anti-sway bars (2)
6. Camber plates/bolts/adjustable upper and/or lower arms (2)
7. Big Brake Kit (includes calipers/rotors/pads) (3)
Admission Costs:
$25.00 – Drag Racing Tech Card
$25.00 – Autocross
**$40.00 – Drag Race & Autocross
**Participating in both activities may prevent you from running in the drag racing eliminations**
Autocross Help Page
Last edited by CivicSiRacer; Mar 20, 2004 at 06:14 PM. Reason: References to foreign board removed. GAK.
Old Feb 17, 2004 | 07:20 PM
Morpheus 6's Avatar
Morpheus 6
Banned
2 points for lightweight fenders?
That's pretty steep.
Old Feb 18, 2004 | 07:02 AM
CivicSiRacer
It's at the front of your car which means less weight over the front wheels.
Autocross Help Page
Old Feb 18, 2004 | 07:35 PM
Eddiebx's Avatar
Eddiebx
damn it i start off stock at class 6, and i am +47 pts, up against s2ks and itrs,
perhaps i should lie about all the things you can't see,
Old Feb 18, 2004 | 08:19 PM
CivicSiRacer
That would not be cool. Why would you want to win knowing you cheated?
I just barely stayed in class 4
Which I took 2nd last year by like 0.1 seconds.
Autocross Help Page
Old Feb 19, 2004 | 07:22 AM
Eddiebx's Avatar
Eddiebx
hehe, i guess i'll see yah there,
lemme ask you, is it worth entering just for shits and giggles? I aint autox my car yet or any car as a matter of fact, planning to start this season though. And are the tech inspections for the autox part alot more strict than the regular ones? cuz i think the tech inspection for the drag racing is a joke there.
Old Feb 19, 2004 | 07:38 AM
honda_pilot's Avatar
honda_pilot
DeeCeeFo'
werd. I'd be going just for shits and giggles as well. To see how I can do on the auto-x with Jens stock RSX-S and see what kind of stock time I can pull in the 1/4 mile with the RSX-S...
I'm wouldn't be in it for trophys or even to compete.
Old Feb 19, 2004 | 09:12 AM
CivicSiRacer
Of course it's worth it. Anytime you get more seat time the better off you are.
I know several guys who showed up last year and never even done anything like this and had a blast. Then I started seeing them at every event
You do have to make sure your car is safe or you will not be able to run. Even me as a competitor if I see your car is unsafe I will say something. Not only because you could put your life in jeopardy, but you put everyone else on course who is working (for free mind you) in the same situation.
This is my pre-check list before I compete:
  • lugs torqued down to specs
  • loose items removed from the car (CDs, change, bottles, etc...)
  • throttle cable returns to idle
  • brake pedal has feel
  • battery is held down securely
  • trunk is empty (remove the spare and jack)
Autocross Help Page
Old Feb 20, 2004 | 11:06 AM
Eddiebx's Avatar
Eddiebx
sweeet, so I guess i'll see ya there, I hope your in class 3 also, then we can race, :P
Old Mar 1, 2004 | 05:05 AM
Asahi's Avatar
Asahi
Administrator
I think the classification of the RSX-S is a mistake. The RSX-S these days is capable of being as fast or faster than a Type-R. Handling will take some work but from a power stand point little to no work gets you 200+ whp.
Jessica
Jul 26, 2003 06:22 PM
drdavidge
Apr 27, 2003 08:34 AM
KingPin
Apr 11, 2003 09:08 PM
JMU1337
Meets & Events
Apr 1, 2003 08:14 PM
