Workout crew advice
This might be psychological, but I think my right boob is bigger than my left one.
h: Uh ohhhh, not visually noticable but it feels bigger.
I think it's happened beause of my damn bench when it's declined. Stupid thing is too steep and I slide down because the weights i'm lifting make it heavy.
Anyway to correct this? Should I balance it out for a week by using 60% on left and 40% on right?
h: Uh ohhhh, not visually noticable but it feels bigger. I think it's happened beause of my damn bench when it's declined. Stupid thing is too steep and I slide down because the weights i'm lifting make it heavy.
dunno, maybe try to work out that side more? :dunno:
as for me, I finally started lifting again, :nervous:
I wasn't as weak as I thought I'd be, I left off at 220lbs reps, started at 170lbs :happysad:
I'm 120, i'm lifting 130.
h: SPAM for me.
h:
Originally posted by evolution
That's not bad, how much do you weigh?
h: SPAM for me.
h:
h: SPAM for me.
h:
h:it shouldn't take me long to get back to 220lbs reps, just need to stay disciplined. I hope to get up to 280ish by summer.
This is why I prefer dumbells over barbells. You can't cheat by having your stronger side pick up the slack. Using dumbells, each side must but out the same effort otherwise you won't get the weight up.
when u actually work out ur body enough....the two sides will get even...eventually...
but dumbells are good....u need to get ur forms straight though...
i wouldnt start on dumbell by myself...get someone to train u first..
