workout guys: losing weight question
Old Oct 3, 2003 | 02:48 PM
kento's Avatar
kento
Default workout guys: losing weight question
when you go on a diet, does the body burn fat first, or muscle first?
Old Oct 3, 2003 | 02:50 PM
SUPER LAUBO's Avatar
SUPER LAUBO
KiMBO's Hubby
burns the carbs you already took in first then goes to your stored energy a.k.a. FAT!!!! that's what the Ackin's diet is essentially about, balancing your carb intake so the calories burned comes directly from your fat...
also, forget all that talk about diet this, diet that... it comes down to one thing:
exhaust more calories than you intake. :thumbup:
Old Oct 3, 2003 | 02:52 PM
kento's Avatar
kento
so does your body every use muscle for energy before it uses all of the fat?
Old Oct 3, 2003 | 02:53 PM
HawtPants's Avatar
HawtPants
the one and only
i thought that fat is the last thing your body burns, diet or not.
Old Oct 3, 2003 | 02:57 PM
b_dyche's Avatar
b_dyche
owned by a 9 car pile-up
depends on the diet...
probably the easiest, cheapest, and most effective way to lose weight is to cut 1/3 of your protein intake, drink a ton of water instead of soda (useless calories), and increase your fruit intake (instead of chips & candy... more useless calories).
Right now I eat more than I've ever eaten since I was like 15, and I lose over a pound a week, due to eating healthy, and a bit of running... (2 days a week, ~ 3.5 miles per run) and I lift 3-5 days a week (probably counter-acting some of the weight I'm losing)
At any rate, weight loss is a simple formula of calorie intake vs. body needs. ~3500 calories = 1lb., so by cutting protein (dense, generally fatty food) and adding fruits & vegetables (you can eat as much salad as you want - sans fatty dressing - and not gain a pound) you would be surprised at how many calories you cut out in a week.
Set a small goal, 5 lb/mo and just watch the intake...
On a starvation diet, probably muscle first.
A substitution diet will burn more fat than muscle, and with a little toning exercise will add some nice definition, too.
Old Oct 3, 2003 | 02:58 PM
kento's Avatar
kento
well, i'm not in need of losing any weight, this is about an argument a friend of mine and i are having... he said that muscle and fat are burned at the same rate, and that doesn't sound right to me.
Old Oct 3, 2003 | 03:05 PM
SUPER LAUBO
KiMBO's Hubby
www.howstuffworks.com :thumbup:
Old Oct 3, 2003 | 03:27 PM
JJJ784's Avatar
JJJ784
No Soup For You!
:werd: buring fat requires aerobic respiration. that's why you do aerobic/cardio to burn the fat. first do weights to burn glycogen, then cardio to burn fat. not strenuous cardio either. that will just make you go into anaerobic respiration and produce more lactic acid. slow down the intensity and the oxygen will help relieve the lactic acid and "pain"/cramping due hypoxia. remember that muscle cells burn more calories than fat cells, and that fat cells only grow bigger and divide. they do NOT decrease in numbers when you diet. they just shrink in size.
blah, i think i might be talking outta my ass. WHEEEEEEE!
