Need help from workout squad
Old Jun 24, 2003 | 07:52 PM
Matt86's Avatar
Matt86
vtec ownz j00
Default Need help from workout squad
I need to get in shape for soccer and i want to look good for the new school year. So what should i do to built up my running endurance and get toned? ANy advice on eating and exercise routines?? Thanks
Old Jun 24, 2003 | 07:55 PM
KirkLS's Avatar
KirkLS
Wannabe ///M3 owner
well to get up your running endurance I would suggest running. To get toned just lift a low amount of weight with a lot of reps to tone yourself. I would suggest doing chest and biceps because they stand out when people see you
alpha's Avatar
alpha
run.
and eat sensibly. not necessarily like you would if you were in season, well, if you want, you could.
but work on your cardio for the endurance, and lift some to get toned.
Old Jun 24, 2003 | 07:56 PM
Matt86's Avatar
Matt86
vtec ownz j00
how far and often should i run? I was thinking about 5 miles every day. Also how much weight are we talking for becoming toned? Like 50lbs?
Old Jun 24, 2003 | 08:01 PM
airon's Avatar
airon
AARONNOJIMA.COM
as you probably know, try and work out in the morning
the more you workout the more intake you should be having
also 5 smaller meals a day is advised, rather then 3 larger ones
Old Jun 24, 2003 | 08:12 PM
KirkLS's Avatar
KirkLS
Wannabe ///M3 owner
depends on the exercise. For bench press if you can do 135 lbs for 3 sets of 10 then I'd say do 3 sets of 15-20 reps with 100 lbs on. Whatever weight you can do 15-20 reps with for other exercises
Old Jun 24, 2003 | 08:21 PM
LT's Avatar
LT
The deer had to die!
work on your lateral muscles (side muscles, connect from arm to chest side) to get a nice V-look
Old Jun 24, 2003 | 08:58 PM
reech-around's Avatar
reech-around
RIP Woong.
this sh*t really works :thumbup: it will give your lower abs/pelvis area the "superman" triangle shape
Old Jun 24, 2003 | 08:59 PM
Matt86's Avatar
Matt86
vtec ownz j00
are there any good exercises to do these without using weights?
