i am having car troubles..a lil help please.
Originally posted by WiLL
i assume the battery is fine because the headlights and dash lights still turn on. and engine wont crank or turn at all.
Good luck.
Originally posted by reno96teg
engine will still turn over without fuel, if everything is in order.
Either battery or starter is my guess since you can't even turn the engine over. Try jump start with another car. If it still doesn't turn over, then it's bad starter. It it turns over, then it's bad battery. Hope that helps.
thanks...
just to clearify, whats the difference between turning over and cranking? i thought they were the same: when the engine is trying to start, but just not making it. that ehhh ehhh ehhhh ehhh sound.
h:
h:
that sounds like either fuel or spark.
check fuel pump, check spark plug
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
thanks...
h:
thanks...
h:
when it fires i was taught it has "turned over"
i dunno why, perhaps it implies it has "turned over" to burning fuel instead of electric. perhaps it is a throwback to the old crank-days when "cranking" the car meant stooping at the front bumper and putting your back into it to literally crank it, and "turning over" was when the crank started turning on its own.
