So about my overheating car
Old Jul 9, 2010 | 06:14 AM
marvinp8700's Avatar
marvinp8700
if the price is fair
i suppose you might find some answers here but i tend to seek my g35 answers there.
Old Jul 9, 2010 | 06:16 AM
ShaolinLueb's Avatar
ShaolinLueb
not to sure where it is tark. i know sometimes cars with bad thermostats have over heating issues. go over to the g35. thermostats aren't the cheapest so check before you replace it.
Old Jul 9, 2010 | 06:23 AM
Civic2Scooby's Avatar
Civic2Scooby
seriously? Thermostats are like 7 dollars.......
I would also have your radiator cap tested. If it is failing, it will allow pressure to escape under high heat ie with the A/C on and allow the coolant to become de-pressurized and overheat.
Old Jul 9, 2010 | 06:27 AM
Tark's Avatar
Tark
hmm... that's a good point. a rad cap can't be all that expensive and chaging it certianly cant hurt.
Old Jul 9, 2010 | 06:34 AM
you'd have prolly 30 bucks or less in a thermostat, cap and top off fluid for whatever you lost in changing the stat lol
Old Jul 9, 2010 | 07:27 AM
Tark's Avatar
Tark
Marvin thx for the bump LOL
Old Jul 9, 2010 | 09:38 AM
marvinp8700
no prob
Old Jul 9, 2010 | 10:40 AM
dE.fUsEd's Avatar
dE.fUsEd
I still like honda's. :-/
Are you absolutely sure that both fans are running when the A/C is on?
On my wifes jeep liberty, it was recently overheating in the exact same manner yours is.
Every time I looked under the hood, I could see the fan working.
Well, turns out, this fan is a 2 stage fan. It comes on when the A/C is on, and should come on at a certain temperature. It wasn't coming on when at the certain temperature. So when the A/C was on, it would stay on. But every few minutes when the A/C compressor would kick off (all a/c's do this), the fan would kick off. This is supposed to give the engine time to cool off, but instead when the A/C would kick off, the car would get hotter.
Kind of hard to explain, but a new fan ($300 later), and the issue is gone.
Other than that, the thermostat is usually an easy and cheap fix. You can pull yours out and place it in to a pot of boiling water to test if it is opening correctly.
Old Jul 9, 2010 | 10:51 AM
Tark's Avatar
Tark
I get what you're saying... But yeah both are working. I even let the car idle without the ac on and both fans started up.
I guess the thermostat is my best bet at this point.
Old Jul 9, 2010 | 12:13 PM
DakarM's Avatar
DakarM
yeah thermostat is probably your best bet. shouldn't be too expensive and fairly easy to replace.... of course i've 0 experience working on a g35 :chuckles:
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
