yo, peeps w/ integra, come inside. :D
Old Apr 1, 2003 | 01:47 PM
ImNoBody's Avatar
ImNoBody
wHo YoU bE?
Default yo, peeps w/ integra, come inside. :D
I would post this in integra forum, but there's not much traffic going on in there. and i need help quick.
I have a 97teg LS.
question is, how do you take out the back seat??? i can't find any hooks or anything to unhook that sonofabish. I know usually there's a button under the seat, just press and the seat will pop up, but what the hizzzy, i can't find jack. or maybe i'm just blind h:
help hlep help :thumbup:
Old Apr 1, 2003 | 01:53 PM
dubcac's Avatar
dubcac
I
Ok. Pull the tabs on top of the upper backseat so that they fold down. You should be able to pull the seats side to side and get the upper parts out. Then there is a 10mm bolt holding the bottom seat in. Remove that, then pull up on the seat to pop it out.
Old Apr 1, 2003 | 01:55 PM
Daniel's Avatar
Daniel
- Unvelcro the carpet in the trunk from the wood panel. Bunch up next to back of seat.
- Climb into back seat and reach hand down between side interior panel and seat. Look for a little "male" plug into a "female" hole. There should be a black, plastic thingy that you must push out from underneath.
- Once both sides are out, slide seats fartherest away from each other, towards side interior panels. Look down in same location as before except in the middle between the seats and slide "female" hole out of metal "male" plug. Do same for other back seat and it's out. Fold up neatly and you may wish to disconnect the carpet too by gently plying the plastic plugs off.
- Unscrew bolt from bottom of floor where little "U" metal shaped thingy goes into seat.
- Flip bottom of seats up and at the front will be two metal prongs that are bent. You will need to contort the seats so that the metal prongs slide out from the hole they are in.
Viola, seats are out!
Old Apr 1, 2003 | 01:56 PM
ImNoBody's Avatar
ImNoBody
wHo YoU bE?
:bowdown:
I'ma go try it now.
Old Apr 1, 2003 | 01:58 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Here you go. From the Haynes manual...
1. Remove seat cushion bolts (look in joint @ seat back hinge); one bolt on either side.
Remove seat cushion and fold seat back down.
2. Remove seat back trim (the carpet on the trunk side), and use pliers to remove the pivot clips (or bolts as applicable) for each seat back.
