Don't they also get two fighters for protection during all flights as well. I would assume this would go for AF1 and the bitches plane as well being the "first bitch" and all...lets also calculate that the second plane was overloaded by about 300 pounds....Oprah been hitting the midnight snacks again.
Don't forget the three choppers they use to get to the plane. each time.
Like i said, i used numbers i can prove, you are guessing.
in my opinion they spend 10 million dollers per gallon. let's use that.
Also, 70% loaded? That's like calculating the presidential limos MPG based on the MPG of a stock caddy.
you dont know anything about aviation do you? with all the extra shit the VC--25 has it's only actually 1 ton heavier then a normal 747-200. A fully packed 747 (500 people, food, water, bagage, cargo, freight, full gas ect...) will be fuck load more then the VC-25.
In fact if the VC-25 wasn't that light it's maneuverability would be seriously impaired.
i'm goin' with tarek on this one. just because he flies planes.
not saying he is including all this "two fighter jets, five helicopters, six limos, time on the ground and taxing" blah blah, but as far as just flying cost goes, i'm listening to him
