Car heating question
Old Jul 2, 2009 | 06:47 PM
Default Car heating question
Hey fellas,
Question about my Sentra. Not sure how long this has been happening, but i just noticed it tonight when i was going to pick someone up who was lost trying to get to my apt. I was chilling at the light and i noticed my temp gauge started going up and stopped at about the middle mark and didn't go any further. I would start driving and it would go back down again. When it was in the middle i got out the car and the fans were on. I know it's not the thermostat because that was just replaced plus it wouldn't cool off at all. I'm wondering if i need a radiator flushing or if my radiator is going bad.
Any suggestions?
Old Jul 2, 2009 | 07:02 PM
Nightshade's Avatar
Nightshade
un-Touch'd krew
It goes back down because air is being moved over the radiator fins cooling it more efficiently than the fans alone.
I would say normal behavior.
Old Jul 2, 2009 | 07:10 PM
Bumnah's Avatar
Bumnah
So OG it hurts.
Bleed the system perhaps. I don't know what year sentra you have, but the older ones were just dummy lights. It didn't have an actual sensor that monitored coolant temps. It just had a sensor once it reached a certain degree of temperature it just aid "hot".
Perhaps the newer ones actually monitor the temps.
I'd bleed the system once for peace of mind.
Project EVA - The Track Package
Project EVA
Old Jul 2, 2009 | 07:12 PM
dubcac's Avatar
dubcac
I
Definitely bleed the system/replace the coolant. It should never reach the halfway point.
Old Jul 2, 2009 | 08:11 PM
BetterBob's Avatar
BetterBob
Nobama
Are you sure the fan you heard was the radiator fan, and not the AC fan?
If it has two, one may not be working. Being the one kicked on by your temp sensor.
Old Jul 2, 2009 | 08:18 PM
A-series's Avatar
A-series
v-card member alpha
Check the coolant levels just to be safe, it should be up to the filler neck of the radiator when you remove the cap (after it's cooled down) and there should be fluid in the overflow/reserve tank even when everything is cooled down.
Hard to say when you're not familiar with a particular brand, let alone that model. Some temp. gauges are meant to show the small normal fluctuations in coolant temp. but some aren't. Reaching the middle of the gauge is normal for some cars, for other above 1/4 is unusual.
If you are driving at a good speed (30+), no matter the temp. outside, with the A/C off, you should be able to come to a stop and not have the cooling fan running as soon as you get out of the car.
