HAN i need help ASAP!
Old Apr 27, 2009 | 04:32 PM
  #51
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Where are you grounding everything? Don't ground it to the metal backing of the seat. That would work, but its best to ground it directly to the body.
Old Apr 27, 2009 | 04:35 PM
  #52
BetterBob's Avatar
BetterBob
Nobama
Re-wired the HU ground and switched RCA's.......still nothing. :shrug:
Do you live under power lines or something?! Their has to be something else...
Try testing all the variables elsewhere.
This too. And grind the paint off of your grounding site, metal to metal.
Old Apr 27, 2009 | 04:45 PM
  #53
BetterBob's Avatar
BetterBob
Nobama
On a side note, what happened to our car audio guy out of Tampa?
Xcaraudio i think?
I thought he should be here by now.
Ah, here he is
Old Apr 27, 2009 | 05:05 PM
  #54
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
hey, i posted already.
What are you running for a ground f/ the amps? also, what gauge wire? best place in a trunk is where the seats bolt to the body i've found....just grind it down first
Old Apr 27, 2009 | 05:15 PM
  #55
BetterBob's Avatar
BetterBob
Nobama
Ah, so you have, i missed that.
Old Apr 27, 2009 | 05:52 PM
  #56
just go to a shop already
Old Apr 27, 2009 | 05:56 PM
  #57
BetterBob's Avatar
BetterBob
Nobama
Their is not many things that can cause speaker noise...
It would be like sending someone that works on their own car to a shop for a car turning over but not starting...
Nothing that complicated, but it has to be narrowed down. So we can isolate and fix the problem.
We have experts on here, and that is what this forum is for.
Old Apr 27, 2009 | 06:03 PM
  #58
b00gers's Avatar
b00gers
I didnt read the thread too carefully....so do this if it applies
Leave everything in place...swap amps. See if it is a problem with the amp itself.
Old Apr 27, 2009 | 06:10 PM
  #59
BetterBob's Avatar
BetterBob
Nobama
Good plan
Old Apr 28, 2009 | 02:46 AM
  #60
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
I unskrewed one of the huge bolts under that back seat and grounded it there. then ran a 4g wire to a distribution block. From there both amps and cap are ground via distribution block with 8g wire.
