Integration Help
integrate f(x)=3x+2
we get
3(x^3)/3 +2x/1
simplify
x^3 +2x
now evaluate at x=3, and x=1
3^3 +2*3 =15
1^3 =2*1 =2
subtract them
15-2=13
answer is 13
this is a super simple problem, did you just start integration?
we get
3(x^3)/3 +2x/1
simplify
x^3 +2x
3^3 +2*3 =15
1^3 =2*1 =2
subtract them
15-2=13
answer is 13
Rachel Bilson
Explain this to me then
Approximate the area under the graph of f(x) and above the xaxis using the following methods with n =4.
1.) Use left end points
2.) Use right end points
3.)Average the answers in parts a and b
4.) Use midpoints
4.) Use midpoints
oh shit you are starting from the beginning
did you attend class the day they did this crap?
its a visual representation of what integration means
integration tells you the area under a graph to the x-axis, positive aread
doing the endpoint thing what they mean is that to calculate the area under a graph physically they break the area into rectangles that have their tops with either the right top corner, left top corner, or midpoint touching the eqaution on the graph
then you use the area of all these little rectangles to estimate the area under the graph
using the 3 different placements of the points give you slightly different answers, and you will see that the more rectangles you use the closer to a perfect answer you get
thus what integration really does is an infinite number of rectangles, giving a perfect slution
Rachel Bilson
He threw 5 sections at us this week, and he started discussing this with 5 minutes left and gave us homework on it...I know what it means, but how the fuck am i supposed to fucking do it
