xbox crew need some help.
Old Feb 13, 2009 | 04:49 PM
ShaolinLueb's Avatar
ShaolinLueb
Default xbox crew need some help.
got a hd tv finally. (used from friend).
so i went out and bought rocketfish hd component av cables tonight. get home. hook them up. and boom, the tv scrambles. took them all out, made sure switch was on hdtv. everything is hooked up right. only thing i can figure is the tv on hd is broken or else the cables suck.
Old Feb 13, 2009 | 04:58 PM
94civicEX's Avatar
94civicEX
I got worms.
Is the slider set to HD?
99 Integra GSR
06 TSX
duck squad member #00003
Old Feb 13, 2009 | 05:01 PM
ShaolinLueb
yes, its set to hdtv. i tried the cables and audio with it set to tv and it worked fine.
Old Feb 13, 2009 | 05:06 PM
94civicEX's Avatar
94civicEX
I got worms.
You sure that the TV is HD? Does it require an HD tuner?
99 Integra GSR
06 TSX
Old Feb 13, 2009 | 05:08 PM
aux's Avatar
aux
More Black on Black Crime
whats rocketfish
Old Feb 13, 2009 | 05:12 PM
dE.fUsEd's Avatar
dE.fUsEd
I still like honda's. :-/
Change resolution in Xbox Settings. Settings/Console Settings/Tv Format.
You probably have it set to a higher resolution than your tv supports. Try 480i, 480p, 720i, then 720p, 1080i, ect.
Without HDMI, you can't use 1080p.
Old Feb 13, 2009 | 05:17 PM
sherwood's Avatar
sherwood
I missed Sean
glad to have hdmi crew :wavey:
your TV should support most inputs though- maybe you have the wrong cables on the wrong inputs?
Old Feb 13, 2009 | 05:37 PM
ShaolinLueb
i dont even f-ing know. the xbox recognizes it. im trying to find the manual for tv. i might jsut give up and return these f-ing cables.
all the inputs are correct.
edit*
here is what its doing.
File Type: jpg
sherwood's Avatar
sherwood
I missed Sean
just suck it up and watch it like you used to watch porn without he box in your parents bedroom
Old Feb 13, 2009 | 05:45 PM
aux's Avatar
aux
:lmao: memories. the Spice Channel > *
is that a boob or elbow h:
