what size power supply.....
Old Oct 1, 2008 | 10:11 PM
James3370's Avatar
James3370
aka Heywoodjablowme
Default what size power supply.....
......would i need to run 10-15 120mm case fans in my aquarium canopy i am building??
:crazyr:
plan so far is to have (2 or 3) on each end blowing inward across the lights, (6) on the back blowing inward on a 45-degree downward angle onto the water & maybe (3) on the front part of the lid blowing outward. there will be a 3/8" gap all around the bottom for additional air circulation
Old Oct 1, 2008 | 10:57 PM
DakarM's Avatar
DakarM
i would say 5v x .5a x number of fans for 10 = 25w figure 20% overhead. you wont need much power.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Oct 2, 2008 | 07:35 AM
AP2's Avatar
AP2
Moderator Alumni
Yes that's not asking too much, 300w maybe?
Old Oct 2, 2008 | 03:30 PM
James3370's Avatar
James3370
aka Heywoodjablowme
so basically, what you are saying is the butt-cheapest one i can find??? LOL
would there be a better way to power them than just using the necessary plug off a pc power supply w/ multiple y-adapters????
Old Oct 2, 2008 | 05:59 PM
AP2's Avatar
AP2
Moderator Alumni
Well you should take a look at modular PSUs if you don't want clutter
Old Oct 2, 2008 | 07:04 PM
Misa's Avatar
Misa
Pic Whore
a full PC power supply is overkill just to run a few case fans.
find an old power brick and use that.
Old Oct 2, 2008 | 07:13 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
http://www.totse.com/community/showthread.php?t=2158516
Try that.
DC adapter, get your fans. Hook the positive from the power to the red on the first fan. Then you can link negative of fan 1 to positive of fan 2, negative of fan 2 to positive of fan 3, etc etc.
Old Oct 2, 2008 | 07:21 PM
Misa's Avatar
Misa
Pic Whore
wiring them in series will split the voltage.
they need to be wired in parallel so all fans recieve 5/12 volts.
Old Oct 2, 2008 | 07:22 PM
DakarM's Avatar
DakarM
LCD Squad #0001
Old Oct 2, 2008 | 07:23 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
:doh: My bad.
