what size power supply.....
Old Oct 2, 2008 | 10:08 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
If you do decide to use a PSU: http://forums.slickdeals.net/showthread.php?t=939108
Newegg has OCZ 2GB (2x1GB) DDR2 800 (PC2 6400) Desktop Memory for $19 after $25 Rebate.
They also have OCZ 500 Watt ATX12V Power Supply for $45 after $20 Rebate.
If you purchase both as a combo, you save $20 and pay $44 for both after rebate with free shipping
Old Oct 3, 2008 | 02:37 PM
James3370's Avatar
James3370
aka Heywoodjablowme
Originally Posted by Misa 5
wiring them in series will split the voltage.
they need to be wired in parallel so all fans recieve 5/12 volts.
would the easiest way be to solder the plug from the pc power supply to the dc adapter & then use y-adapters for all the fans???? that way if the dc adapter goes bad, it's just a matter of soldering a new one to that one end rather than all the fan wires??
i found an adapter from an old dsl modem i had laying around. the end says:
AC/DC Adapter
Input: 120v ~60Hz 230mA MAX
Output: 12v 800mA
will that work with This package of fans i am looking to buy for this lil project??
**edit** looks like each fan has a male & female end for wiring each in line, so i guess i'd just need the end from a junk pc power supply to solder to the dc adapter......so would the ac/dc adapter i posted above in this post be more than enought to power these (15) fans???
Old Oct 3, 2008 | 03:29 PM
Kaspin's Avatar
Kaspin
1991 Prelude Si 4WS
typical 120mm fans use about 150mA each.
Something like this with 4A, should do what you want.
Old Oct 3, 2008 | 03:37 PM
sherwood's Avatar
sherwood
I missed Sean
I'd just twist and cap or maybe heat shrink if I was getting fancy
those connectors supply 5 and 12 volts with two grounds in the middle, not sure if the fans require both or one or the other though- maybe someone here does?
Old Oct 3, 2008 | 08:26 PM
DakarM's Avatar
DakarM
AC/DC Adapter
Output: 12v 800mA
the ac adapter isn't putting out enough amps. I would figure min.250ma upto 500ma for each fan.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Oct 3, 2008 | 09:51 PM
James3370's Avatar
James3370
aka Heywoodjablowme
gotcha.....put the one posted by Kaspin in my ebay watch list. think i might be able to rustle up a few from work where we got replacement laptops last week & some people forgot to send the power supply for their old laptop back
:rick:
so (15) fans at a maximum of 500ma each = ~7.5amps, so if i can find something at that range, i should be gravy?
Old Oct 5, 2008 | 07:43 PM
James3370's Avatar
James3370
aka Heywoodjablowme
rounded up 3 seperate power supplies from various laptops we have had over time & think i'll have one for different times of day depending on what lights are running in the tank
Old Oct 5, 2008 | 08:30 PM
Zackk's Avatar
Zackk
www.drsfostersmith.com
full kit.
