Network connection help!>!??!?!?!
Old Jan 7, 2008 | 11:22 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
gimme 5 mins and I will reset your internet :chuckles:
Old Jan 8, 2008 | 12:06 AM
Brar's Avatar
Brar
Originally Posted by Jani 5
• UDP 88
• UDP 3074
• TCP 3074
have him open and map those ports to your router's public IP
then open those same ports on your router and map them to your xbox.
keep the ip and dns in the 360 settings auto
go into the router, use ip 250, and open ports said above. save, play
Old Jan 8, 2008 | 04:42 AM
can not do :hs:
its a custom network with custom dns and ip settings so i have to manually set the 360 ... guess im just SOL
Old Jan 8, 2008 | 05:05 AM
pay for your own internet
Old Jan 8, 2008 | 06:37 AM
sooo ... i just did some brainstorming with the guy in charge of our store network setups and we came up with a simple solution. build a new seperate network outside the one in the store below my apartment. i just went out to the equipment cage and aquired myself a new switch, some cabling and some mounting hardware and when i go home tonight im going to place my network on a seperate setup from the internal one. going to run the modem into the switch then run seperate lines from there to my apartment and the office.
the IT dept really hates doin stuff that leaves machines on their networks open but with ma friendly connections internally they are more than happy to do what i need to get done. he was willing at first to start opening the ports for me and/or set my xbox ip up in the DMZ before i realized i could just bypass everything
Old Jan 8, 2008 | 06:41 AM
you need ur own internets brah.
Old Jan 8, 2008 | 06:42 AM
imma have it now ... i just share the speeds
besides free > monthly charge
Old Jan 8, 2008 | 06:43 AM
when it's all fired up, you should leave high uploading torrents on all day.
