loud knocking sound when gas pressed
Old Nov 30, 2007 | 02:17 PM
v6_accord_jerz's Avatar
v6_accord_jerz
Stupid Power Ball
Originally Posted by puffy
^guesstimate?
If you provide the parts on a build.......~$600-$1000 depending on where you go. That's what i would think it would cost labor wise.
Old Nov 30, 2007 | 02:21 PM
dubcac's Avatar
dubcac
I
Agreed...if it's not detonation, either spun bearing causing rod knock or the piston to hit the head, or could be piston slap caused by out of round/spec cylinder bore or piston. Gonna be some $ to fix.
Old Nov 30, 2007 | 03:30 PM
puffy's Avatar
puffy
bow down to king puffy
I think thats it unfortunately
Old Nov 30, 2007 | 03:31 PM
dubcac's Avatar
dubcac
I
My old roommate actually spun a bearing and didn't have rod knock...but the piston was hitting the head. The "IN" stamp on the piston was pressed into the bottom of the head. We thought it was rod knock until we pulled it apart. o:
Old Nov 30, 2007 | 03:35 PM
puffy's Avatar
puffy
wow, either way I need to find honda tech in socal fast
Old Nov 30, 2007 | 04:55 PM
puffy's Avatar
puffy
if its bearing, cant I just replace it from bottom? removing oil pan?
Old Nov 30, 2007 | 04:58 PM
jaymar88's Avatar
jaymar88
HA.net Workout Krew
With the GSR?? Yes. Drop the pan, the pickup and you can get to the bearing caps from there
Old Nov 30, 2007 | 05:03 PM
dubcac's Avatar
dubcac
I
Assuming there was no scoring to the crankshaft, yes it can be fixed with the motor in the car.
Old Nov 30, 2007 | 05:06 PM
puffy's Avatar
puffy
thanks jay, so we are talking about main bearings and not rod bearings
Old Nov 30, 2007 | 05:13 PM
jaymar88's Avatar
jaymar88
HA.net Workout Krew
Rod bearings/main bearings get intechanged all the time, but can mean the same thing.
Drop the pan, unblot the rods and look for scoring on the caps... if there is, I'd just pull the motor and rebuild.
The motor comes out super fast. You could get it out and broken down in one day and back together in another weekend.
