Optical cable hook up
Old Oct 4, 2007 | 10:45 AM
randomtask77's Avatar
randomtask77
Wanderer
Default Optical cable hook up
Anybody use an optical cable to hook up their home theater to their TV?
For a while I was using RCA's to connect my Samsung HTIB (upconvert DVD player) to my Samsung LCD and it worked great, but it I had a small hassle to get audio to play through the home theater speakers. By the way, this is watching cable TV. Playing DVD's does not develop the same problem, only when I want to hear cable TV through the home theater speakers.
Tried using an optical cable (bought from Amazon.com) and though it worked and it got rid of my "hassle" now I get crackling from the speakers every now and then. Is this normal from using an optical cable?
Old Oct 4, 2007 | 10:49 AM
optical cable has light signals passing though.
make sure to keep the cable as short as possible and in a straight line.
On an unrelated note, Psyclone branded optical cable for the Xbox 360 is on clearance @ Target for 2.48.
Old Oct 4, 2007 | 10:51 AM
sqkev's Avatar
sqkev
not normal, try different decoding formats that your receiver offer.
Old Oct 4, 2007 | 10:52 AM
sqkev's Avatar
sqkev
wrong!
Civic2Scooby's Avatar
Civic2Scooby
even if he has some loops or a long line, it should never degrade sound quality. I have all my audio hooked up through optical line, as it is a much nicer, crisper quality.
Old Oct 4, 2007 | 10:54 AM
randomtask77
Wanderer
Well it's only about a 2ft. cable and I can't help it if the cable isn't in a straight line. I just plugged it to the back of the TV to the back of the DVD player/receiver.
Civic2Scooby
yeah, the straight line doesn't matter.
Old Oct 4, 2007 | 10:55 AM
Originally Posted by sqkev
wrong!
are you retarded? honestly now.
http://www.crutchfield.com/ISEO-rgbt...me/cables.html
Optical cables transmit digital audio signals as pulses of light.
Because they use pulses of light rather than electrical impulses to transmit audio signals, optical cables are virtually impervious to interference. It's still important to look for a well-made cable, however: a quality fiber-optic element can prevent jitter, while solidly built connectors add durability.
You won't get static interference from other devices ... but if you have a kink in the line, the light can't cut though corners.
:shake:
when I say straight line, just don't kink it.
Old Oct 4, 2007 | 10:56 AM
randomtask77
Wanderer
Not sure if this receiver/DVD player is capable of that. h:
Old Oct 4, 2007 | 10:58 AM
sqkev's Avatar
sqkev
:shake:
seriously, do read more, I'm sure you have google at hands.
