Another SQL question - Please assist :)
Old Oct 4, 2007 | 01:26 PM
  #31
Pete's Avatar
Pete
Civilian
Originally Posted by dieneverknowing
Why are you trying to get it to print 'overdue' if that wasn't part of the original task?
It said to list the date that the new test should be completed. If they are past that date then it should say "overdue".
Old Oct 4, 2007 | 01:32 PM
  #32
dieneverknowing's Avatar
dieneverknowing
From this?
Find all pilots that are either overdue on their flight proficiency check or need to have one within the next three months (a test is required every 6 months). List the pilot’s name, date of last check and the date it should be completed. Use the traditional method to solve the problem.
The only way I can think of accomplishing that is to do an IF statement, but I can't see the teacher requiring that if you haven't covered it. But let me look real quick and see what I can come up with
Old Oct 4, 2007 | 03:28 PM
  #33
Pete's Avatar
Pete
Civilian
Finally made some progress
Code:
TTITLE 'RobAir - Pilot Proficiency Test Status'
COLUMN pil_pt135_date -
HEADING 'Last Proficiency Test'
COLUMN req_test_date -
HEADING 'Next Proficiency Test'
SELECT (e.emp_fname ||' '|| e.emp_lname) Pilot, p.pil_pt135_date,
(ADD_MONTHS(p.pil_pt135_date,6)) req_test_date
FROM hartmar.employee e join hartmar.pilot p on e.emp_num = p.emp_num
It will show the pilots dates and thier required dates. I think I might be able to handle the rest. Will respond once I make more progress.
Old Oct 4, 2007 | 03:42 PM
  #34
Pete's Avatar
Pete
Civilian
Problem solved:
Code:
WHERE ADD_MONTHS(p.pil_pt135_date,6) < ADD_MONTHS(CURRENT_DATE,3)
I figured it out while reading the Oracle 9i: SQL book while I was on the shitter. It's amazing what you can accomplish while you are in there.
Old Oct 5, 2007 | 05:00 AM
  #35
dieneverknowing
Good job! :thumbup: Amazing what you can do on the toilet. I also see you didn't include that 'overdue' crap
The ADD_MONTHS is a lot better then just adding the days like I did. I believe I had the same book as you when I took SQL online. For some reason it wound up being the only book I didn't keep from all my programming classes. h:
