tips at the gas pump
Old Sep 30, 2007 | 07:50 PM
Snoopy's Avatar
Snoopy
been there done that
Default tips at the gas pump
1. Fill up your car or truck in the morning when the temperature is still cool. Remember th at all service stations have their storage tanks buried below ground; and the colder the ground, the denser the gasoline. When it gets warmer gasoline expands, so if you'r e filling up in the afternoon or in the evening, what should be a gallon is not exactly a gallon. In the petroleum business, the specific gravity and temperature of the fuel (gasoline, diesel, jet fuel, ethanol and other petroleum products) are significant. Every truckload that we load is temperature-compensated so that the indicated gallonage is actually the amount pumped. A one-degree rise in temperature is a big deal for businesses, but service stations don't have temperature compensation at their pumps.
2. If a tanker truck is filling the station's tank at the time you want to buy gas, do not fill up; most likely dirt and sludge in the tank is being stirred up when gas is being d elivered, and you might be transferring that dirt from the bottom of their tank into your car's tank.
3. Fill up when your gas tank is half-full (or half-empty), because the more gas you have in your tank the less air there is and gasoline evaporates rapidly, especially when it's warm. (Gasoline storage tanks have an internal floating 'roof' membrane to act as a barrier between the gas and the atmosphere, thereby minimizing evaporation.)
4. If you look at the trigger you'll see that it has three delivery settings: slow, medium and high. When you're filling up do not squeeze the trigger of the nozzle to the high setting. You should be pumping at the slow setting, thereby minimizing vapors created while you are pumping. Ho ses at the pump are corrugated; the corrugations act as a return path for vapor recovery from gas that already has been metered. If you are pumping at the high setting , the agitated gasoline contains more vapor, which is being sucked back into the underground tank so you're getting less gas for your money.
i've heard the first one but the rest are new to me. your thoughts.
Old Sep 30, 2007 | 07:53 PM
They make somewhat sense...:dunno:
GSRRacer95's Avatar
GSRRacer95
Fight On!
Thanks for the tips.
Old Sep 30, 2007 | 08:15 PM
Zackk's Avatar
Zackk
:yay: 4 snuupz.
Old Sep 30, 2007 | 08:18 PM
useless's Avatar
useless
i like cheese
i've heard 1 and 2 before but i'll try to remember the others
Old Sep 30, 2007 | 09:17 PM
R_Squared's Avatar
R_Squared
LEVEL UP
I've heard all of them before except for the last one. h:
Old Sep 30, 2007 | 10:07 PM
jconeab's Avatar
jconeab
got the nuts
nice. new things i didn't know.
at first i thought you were talking about tipping at gas stations for service...
Old Oct 1, 2007 | 12:42 AM
project_hatch's Avatar
project_hatch
Power by Uncle Ben's Rice
i've heard or the half full one before
Old Oct 1, 2007 | 02:24 AM
White[Pony]'s Avatar
White[Pony]
For relaxing times...
So basically... pump slow in the late night/early morning when you're half-full and the tanker isn't there.
I can prolly remember that. Thanks noopy!
Old Oct 1, 2007 | 03:27 AM
Civic2Scooby's Avatar
Civic2Scooby
yeah I don't actually care about that .07?% of a gallon I'm not getting by filling up in the afternoon. Also I am not gonna stand there and hold the nozzle for 45 minutes for an extra drop of petrol....
