electrical question....
Old Apr 3, 2007 | 04:01 PM
James3370's Avatar
James3370
aka Heywoodjablowme
Default electrical question....
took the battery leads off my car to clean the corrosion buildup off them & now the power door locks don't work from any button & the power windows on the passenger side don't work from the driver's side controls but do from the passenger side :dunno: & btw...drivers side windows work from drivers side controls
this happened once before when my car was in the body shop a few months ago having some body work done & it all just magically started working a few days after.....
any ideas???
Old Apr 3, 2007 | 04:03 PM
Samson's Avatar
Samson
chris is the devil
what car? the control modules probably need to be programmed by following simple steps.
Old Apr 3, 2007 | 04:09 PM
James3370's Avatar
James3370
aka Heywoodjablowme
98 accord 4-door
last time it happened, it just started working again on it's own a few days later. went to unlock the passenger side w/ the key for my date & heard all 4 doors unlock...... "IT'S ALIVE!!!!"
Old Apr 3, 2007 | 04:18 PM
Samson's Avatar
Samson
chris is the devil
hmmm i dont know then.
Old Apr 3, 2007 | 04:19 PM
regulator :hsdunno:
loose ground
loose connection somewhere
Old Apr 3, 2007 | 04:29 PM
James3370's Avatar
James3370
aka Heywoodjablowme
Originally Posted by rebeld
regulator :hsdunno:
loose ground
passenger side controls passenger side & drivers side controls drivers side, but not passenger, so they work but not from the drivers side....almost like the switch is bad, but cleaning the corrosion off the battery terminals wouldn't cause the switch to go bad
only thing that doesn't work at all now is the power door locks
what gets me is this EXACT SAME THING happened the last time the battery was disconnected when the bodywork was being done & it just magically all started working a few days later & hasn't had a problem since
Old Apr 3, 2007 | 04:30 PM
im going with a ground / wiring issue... or the switch itself could be failing
Old Apr 3, 2007 | 04:31 PM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Try disconnecting the battery again and see if that changes anything.
Old Apr 3, 2007 | 06:43 PM
VPUPPY's Avatar
VPUPPY
how did you reconnect the battery? Positive first, then negative? I believe the multiplexing unit (does the door locks and windows) is located in the drivers door. The passenger side window may work because it's basically controlling the motor directly when you use the switch on that door. The switch on the drivers side goes through the multiplexing unit within the door. Do your rear windows work from the drivers door? A bad ground could cause this issue.
Old Apr 3, 2007 | 08:56 PM
mr22na's Avatar
mr22na
Miss It.
mhhm its april so take it to honda free 40 point inspection =/
