electrical question....
Old Apr 3, 2007 | 09:01 PM
fuse
Old Apr 4, 2007 | 06:04 AM
James3370's Avatar
James3370
aka Heywoodjablowme
Originally Posted by dj02
fuse
if it were a fuse they wouldn't work at all....i have control of each side from its side, but not passenger from driver's side. didn't see a fuse for just the door locks :dunno:
Originally Posted by VPUPPY
how did you reconnect the battery? Positive first, then negative? I believe the multiplexing unit (does the door locks and windows) is located in the drivers door. The passenger side window may work because it's basically controlling the motor directly when you use the switch on that door. The switch on the drivers side goes through the multiplexing unit within the door. Do your rear windows work from the drivers door? A bad ground could cause this issue.
rear works from it's side controller, but no passenger rear control from driver's side
any way to "reset" multi-plexer??
Old Apr 4, 2007 | 06:47 AM
Brar's Avatar
Brar
wait for it to fix itself again
Old Apr 4, 2007 | 07:33 AM
HawtPants's Avatar
HawtPants
the one and only
your relay might be going out. i had a similar but not similar problem with my 240sx. there was a relay attached to the starter, when it was going out it i couldnt start the car, but sometimes it worked, it was weird. a trick was to bang the relay against something hard and it started working again. so i hit my relay with the back side of a screwdriver and it magically started working again until i could get a replacement.
Old Apr 4, 2007 | 09:48 AM
fstop128's Avatar
fstop128
when my car was in the body shop i got a similar problem i think it came from taking the door panel off to take off the outside trim. a loose connection. ive not gotten it fixed. same issue. the pass window works fine with pass side door control and it will work when it feels like it on the drivers side control for the pass window. i have to really push up on the button to get the window to go up yet it goes down just fine from the drs side panel. when u find out the cause let us know. ive had the relays replaced but before the body shop got ahold of the car. wont take it back they will mess something else up.
Old Apr 4, 2007 | 02:38 PM
James3370's Avatar
James3370
aka Heywoodjablowme
my check engine light came on & i went to auto zone to have that checked w/ a code-checker. the guy told me that when the battery is taken of, the computer has to re-check it several times & then it'll just start working again
low & behold, when i left after having the CEL code checked/reset the door locks & window controls all worked again
:loco: that settles it....my car is DEFINATELY a female :lmfao:
Old Apr 4, 2007 | 02:53 PM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
your username is really offensive to me. h:
Old Apr 4, 2007 | 03:01 PM
James3370's Avatar
James3370
aka Heywoodjablowme
then maybe you should join hondabikes.net
obscure thread reference from you :thumbup:
