I'm running a lil' rich...
Old Dec 8, 2006 | 01:20 PM
Pete's Avatar
Pete
Civilian
Default I'm running a lil' rich...
http://lxhomeskilletxl.dyndns.org/al...nning_rich.3gp
Sorry about the crappy quality but it was the best I could do with my phone. Anyway, does anyone know what I can do to lean out my mixture a little? I'm not sure but is it supposed to be stoichiometric (in the yellow) or just a little bit in the green?
Old Dec 8, 2006 | 01:22 PM
AcuraFanatic's Avatar
AcuraFanatic
Advance the timing a few degrees. Check for fouled plugs.
Old Dec 8, 2006 | 01:25 PM
AcuraFanatic
Nevermind, just saw the video. You do realize that it is now colder out right? Beyond that, dont' trust those gauges to save your life.
Old Dec 8, 2006 | 01:30 PM
Pete's Avatar
Pete
Civilian
It was rich in the summer time too. I just didn't really wanna do anything about it till now that it is colder.
Old Dec 8, 2006 | 01:33 PM
2001TEGGSR's Avatar
2001TEGGSR
umm... ditch the narrow band AF gauge.
edit: I used to have one of those and it would read rich like that anything above 60% throttle, or 5,000 rpm's.
Old Dec 8, 2006 | 01:34 PM
AcuraFanatic
Could be a vacuum leak if there's no codes. I don't know, I can't think right now.
Old Dec 8, 2006 | 01:48 PM
dubcac's Avatar
dubcac
I
That gauge is horrible, and should not be used as a tuning tool. Check your plugs to see if they are black and look rich. If they aren't, you're fine. If you want to tune, get on a dyno with a wideband.
Old Dec 8, 2006 | 01:49 PM
AcuraFanatic
Still check for vacuum leaks for peace of mind. Take a can of carb cleaner and spray the TB and intake manifold gasket and listen for a stutter.
Old Dec 8, 2006 | 01:51 PM
dubcac's Avatar
dubcac
I
If he had a vacuum leak, he'd have a shitty idle.
Old Dec 8, 2006 | 01:53 PM
2001TEGGSR's Avatar
2001TEGGSR
Especially with a turbo car, It is worth the Peice of mind to install a wideband o2 gauge in your interior.
