HAN Recommend me a
Old Nov 30, 2006 | 10:03 AM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
The first one is hella expensive! Close to 200 bucks after tax and shipping.
But the second one I like. My dad has it and he likes it a lot, only thing is it has 4 internal bays. I'm planning on having a raptor for my main then 2 or 3 250+ hard drives, at least.
Old Nov 30, 2006 | 10:06 AM
Anthony's Avatar
Anthony
ZOMG Pew Pew Laserbeams
Get external cases with that many hdd's it'll create so much heat that you don't want near an already hot raptor.
Old Nov 30, 2006 | 10:07 AM
Misa's Avatar
Misa
Pic Whore
:werd:
raptors run hot and noisy.
Old Nov 30, 2006 | 10:08 AM
sherwood's Avatar
sherwood
I missed Sean
peice of plywood. no heat problems, dust is easily sprayed off with an air-duster. and it will cost you a few bucks.
Old Nov 30, 2006 | 10:17 AM
M@rshy's Avatar
M@rshy
٩(̾●̮̮̃̾•̃̾)۶
Should I not get a raptor then?
I'm checking out the Antec 900 and I like it so far. Its a bit too gamey for me, but I can deal with it.
For the raptor they have 5.25" hard drive cooling racks that have fans on them. They're supposed to work pretty well.
Old Nov 30, 2006 | 10:20 AM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
That 3rd one by ThermalTake is pretty nice.
I'd get the Dynamat kit for it. It's like $25-30, just stick em around on the inside of the case, helps a noticeable amount.
Get the biggest and slowest fans you can. Big and slow = decent airflow with low noise. I'd probably say no more than 2500rpm on the fans if you want quiet. And make sure to get a PSU with a nice big 120 on it, adjustable would be nice.
My Raptor doesn't run any hotter than my SATA 120 or ATA100 160 or old ATA100 40.
Old Nov 30, 2006 | 10:22 AM
Grifter's Avatar
Grifter
my wd320 runs hotter than my raptor :dunno:
Originally Posted by 98CoupeV6
Kitties are optional, but it would probably be prudent to take them out.
im in your box, takin up space
Old Nov 30, 2006 | 10:24 AM
clickwir's Avatar
clickwir
This might help too. http://www.extremetech.com/article2/...2064993,00.asp
In their test, the Dynamat didn't help much. But they already had a pretty quiet system once they got to the Dynamat. I've put the Dynamat on noisy cases and it's had a good improvement. Especially on cheaper cases that vibrate, really helped cut down on the vibes.
Old Nov 30, 2006 | 10:40 AM
Misa's Avatar
Misa
Pic Whore
more noise. h:
