wtf? Ignition rotor stuck.
Old Sep 7, 2006 | 10:12 AM
white_n_slow's Avatar
white_n_slow
it's my D in a B
Default wtf? Ignition rotor stuck.
I'm doing my dizzy in the shitbiscuit and got everything taken apart, but the damn rotor wont come off. I undid the retaining screw and pulled, nothing. Tried prying from the other end with a flathead screwdriver, nothing. WTF, you're supposed to just be able to pull this thing off.
I know this is kinda on topic, but I figured I might get a larger response here. Move if necessary (89 civic si)
Old Sep 7, 2006 | 10:14 AM
F22B Prelude's Avatar
F22B Prelude
Rachel Bilson
Buy a whole new dizzy
qtiger's Avatar
qtiger
I'd give it a light tap with a rubber hammer, see if you can shake it up a bit.
Old Sep 7, 2006 | 10:50 AM
white_n_slow
it's my D in a B
winnar! Well, more or less. I put the butt of my screwdriver to it and whacked that from a few angles, but still had to pry like a motherfucker to get it off. I think I bent up a couple of the ridges on the little thingy to the right of the rotor, but everything seems to be running fine, so meh..
Thanks.
Old Sep 7, 2006 | 11:59 AM
Civic2Scooby's Avatar
Civic2Scooby
told you it was the dizzy h:
Old Sep 7, 2006 | 12:42 PM
white_n_slow
it's my D in a B
your mom.
Old Sep 7, 2006 | 01:12 PM
Llamaguy's Avatar
Llamaguy
The "unofficial" method to removing the dizzy from my car is to take a flat blade screw driver to it and hit it with a hammer to crack the bakelite plastic, take out the bits of remains. Then take a pair of vice grips to the little ultra soft screw that stripped out when you looked at it. Then replace the dizzy with a new one.
Even if you get the screw out, it's almost impossible to actually pull it off the end of the camshaft anyways.
Old Sep 7, 2006 | 02:47 PM
white_n_slow
it's my D in a B
the screw came out just fine, but it was definitely cooked onto the shaft. I was afraid of using brute force because of the relative fragility of the surrounding parts.
