Figure this one out....weird car problem.
Old Aug 22, 2006 | 09:45 PM
98CoupeV6's Avatar
98CoupeV6
lots and lots of fail
Originally Posted by dubcac
If I had your manual, I would. You have it, so you find it.
Hint: It's in the cooling system section, probably with radiator replacement or cooling system flush.
Go to my garage and get it, because I cetainly don't feel like it.
dubcac's Avatar
dubcac
I
Well if there are no leaks and the coolant level stays relatively the same, oil isn't milky, both fans come on....I'd look at the water pump. 180k is the time for the 2nd timing belt and water pump service.
Old Aug 22, 2006 | 09:48 PM
b00gers's Avatar
b00gers
If the water pump is going out....would the car still drive ok like 95% of the time?
Old Aug 22, 2006 | 09:49 PM
AcuraFanatic's Avatar
AcuraFanatic
That's classic signs of water pump failure.
Old Aug 22, 2006 | 09:52 PM
b00gers's Avatar
b00gers
Ok, I told her to ask her dad. I know he did some work on it.
Old Aug 22, 2006 | 09:53 PM
Civic2Scooby's Avatar
Civic2Scooby
yes...
I missed when reading the mileage on the vehicle.....I thought it said 18000 miles...thats why I changed from water pump.
I revert to water pump
Old Aug 22, 2006 | 09:54 PM
b00gers's Avatar
b00gers
yes...
Final answer? h:
Old Aug 22, 2006 | 09:58 PM
Civic2Scooby
Final answer? h:
final answer is its second timing belt water pump time.....
Old Aug 23, 2006 | 07:08 AM
fstop128's Avatar
fstop128
u asked if old parts could be the problem, probably since u put in an old thermostat. so start there with a new thermostat. does sound like a bad thermostat, bad water pump or slowly leaking radiator. could be a leak in a hose. blown headgasket u would have trouble driving it. the car would not want to run or move. the symptoms of slim in the oil cap, white smoke come later. u would notice too alot of coolant is gone. water pumps make a bearing noise also.
Old Aug 23, 2006 | 07:59 AM
b00gers's Avatar
b00gers
Yea, old parts were my first thought. But I will found out about the water pump.
What causes the coolant to overflow and leak out of the overflow tank?
