computer guys...need your help....
Old Mar 23, 2006 | 12:32 PM
egghead's Avatar
egghead
TF Plasti-crack Crew
See the white thing in the middle? The drive connected to the end of the IDE cable should be set on master, and the one connected to the middle of the IDE cable should be set to slave.
Old Mar 23, 2006 | 12:36 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
omg...i would have never figured that out....looks from here though (cant see it very well) like the dvd burner doesnt even have one of those things...or do they ALL have that?...ill take it out n check it out....thanks alot for the help guys!
Old Mar 23, 2006 | 12:42 PM
Misa's Avatar
Misa
Pic Whore
they should all have that
which brand burner?
Old Mar 23, 2006 | 12:48 PM
egghead's Avatar
egghead
It might not be white, but it should looke similar.
Old Mar 23, 2006 | 12:54 PM
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
which brand burner?
NEC....i checked it out...and the cd-rom that came in it is not in either...its in "cable select"....since that ones going on the end if the IDE I should move that thing onto the master right?...and then the dvd burners' thing is on masters...move it to slave?
Old Mar 23, 2006 | 12:55 PM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
Originally Posted by mr.crx
ok i asked this in another thread but here goes does anyone know how to get to myspace otehr then going directly to the site cause my work is gay and blocked it
You should be thanking work.
Old Mar 23, 2006 | 12:56 PM
egghead's Avatar
egghead
Or just swap their positions if you want the dvd burner to be first.
Old Mar 23, 2006 | 12:57 PM
Misa's Avatar
Misa
Pic Whore
either you can put both in CS, or put the burner as master and the cdrom as slave
FLAT_LINER's Avatar
FLAT_LINER
Ridin Dirty
awesome...thanks alot you guys I would have never figured it out....I never thought that stupid thing made a difference i was trying to plug somethin into it haha h: ....
Old Mar 23, 2006 | 12:58 PM
clickwir's Avatar
clickwir
Set one for master and one for slave, if one of them is a hard drive set that one for master. Most newer motherboards can cope with slave being the first or second physically on the cable.
