how do car vents work?
isnt there a fan that draws the heat in?
there is 2 modes. The interior heat and exterior heat (hence the logo). The exterior heat is warmed up thru your heater core then ran thru a blower and out the vents.
Switching to interior heat just circulates the heat in the car and doesn't go thru your heater core.
what if there's no heat inside the car?
Originally Posted by LT
i never understood why one would recirculate heat (minus the A/C).
I think the air does go back through the heater core to get re-heated on Recirc.
Your car has a heater core. Engine coolant circulates through it, and the ventilation system puts air through it to pick up heat from the engine coolant. It works like an invese liquid-to-air intercooler. Instead of the air going through it putting heat into the coolant, the air takes heat out of the coolant and then is pumped into the cabin. Turning on the heat always passes air through the heater core. If you take in fresh air, you suck outside air through the heater core then into the car, and the recirculate sucks air from inside the car, passes it through the heater core, then puts it back into the car. Skipping the heater core wouldn't accomplish much of anything.
