GEEK SQUAD! IE6 crashing...help
Originally Posted by TeggerLS
It's reporting a lot of bad sectors and not enough space to fix them
Originally Posted by janiVI
the drive is failing
http://support.microsoft.com/default...b;en-us;884070
SYMPTOMS
When you start or run a program in Microsoft Windows XP, the program may crash when it tries to read valid data from or write valid data to a storage medium. You may receive the following error message:
Program_name has caused and error and must be closed.
We apologize for the inconvenience. If you were in the middle of something, the information you were working on might be lost.
Please tell Microsoft about this problem. We have created an error report that you can send to help us improve Program_name. We will treat this report as confidential and anonymous.
To see what data this error report contains, click here.
CAUSE
This problem occurs when Windows XP cannot access a file because of a problem with the hard disk that the file is stored on or with the drivers for a storage medium. When this problem occurs, Windows XP closes the program.
WORKAROUND
To work around this problem, follow these steps:
1. Identify the file that cannot be opened. To identify the file, follow these steps:
a. Click Start, click Run, type EVENTVWR, and then click OK.
b. In Event Viewer, click Application log.
c. Click the Source column heading to sort the list by source and to list all the Application Error sources at the top of the list.
d. Search for an event with a source of Application Error and an event ID of 1005.
e. Double-click this event.
f. The file that cannot be opened will be listed in the Description box. Note the file name, and then close Event Properties.
2. Try to open the file again. The problem may have been temporary and may not occur when the program runs again.
3. If you cannot open the file, verify and repair the hard disk file system with the Chkdsk.exe program. Follow these steps:
a. Click Start, click Run, type cmd, and then click OK.
b. Type chkdsk /f, and then press ENTER.
4. Determine whether other files on the same hard disk can be opened. If not, the hard disk may be damaged. If the hard disk is the problem, contact your administrator or computer hardware vendor for more help.
Note You may have to restore the file in question from a backup copy.
STATUS
Microsoft has confirmed that this is a problem in the Microsoft products that are listed in the "Applies to" section.
MORE INFORMATION
The Error Reporting dialog box appears when an error occurs that causes a fatal event in the program. Error Reporting includes an option to send the information about the fatal event to Microsoft. Microsoft gathers information about these types of events in a database to try to identify the cause. For more information about the Microsoft Data Collection Policy, visit the following Microsoft Web site:
http://watson.microsoft.com/dw/dcp.asp?LCID=1033 (http://support.microsoft.com/?scid=h...%3flcid%3d1033)
The following error signature applies to the error message that is mentioned in the "Symptoms" section:
EventTypeName NTStatusCode
InPageError c000009c or C0000185 or C0000102 or C000003F or 00000002 or 00000003
99 Integra GSR
06 TSX
duck squad member #00003
99 Integra GSR
06 TSX
ok, I'm trying to salvage all my gf's music and personal file's now, gonna burn them on cd. I'll try running the checkdisk again after that.
But at the same time, try reinstalling it again. Cause it seems like you can access other files on the same drive.
99 Integra GSR
06 TSX
99 Integra GSR
06 TSX
I'd recommend that.
thanks for the help
Well I backed up all her file's. I wasn't sure if it would work, but we have similar laptops, same brand just a couple model numbers off. Fedex lost her computer disks, so I used the one's that came with mine, worked fine. I'm updating windows now, gonna see how everything goes.
thanks for all the help ppl's
Replace the hard drive, asap. Then install firefox on the new windows install and enable windows automatic updates, choose to not have it install anything without your permission... welcome to never using IE again.
Fuck IE. :wavey:
Fuck IE. :wavey:
