Need some tech help car people.
Originally Posted by DakarM
my money is on the clutch slave cylinder. they generally run off the brake master cylinder, which is why i said to check the brake fluid.
:werd:
happened to me a while back.
it has its own resevoir. and we bled it but it still doesnt work. and i love the car but i want to go drive it off a cliff right now. about 5500 miles ago i changed the clutch, and it worked fine till last night. but if it isnt the slave cylinder then i dont know what it is.
Check for leaks near the clutch pedal?
Same thing happened to my brothers car. The master took a crap and caused the same reaction. Replace both it's very easy to do. Also check the release spring on the clutch pedal to make sure it's not caught in the way or anything and that it's installed properly. You have to bleed the system very throughly it took me probably 20 times of pumping the pedal to get the air out... and make sure when you install the master you bench bleed it first.
like most impatient teen agers, i just wanted a way to rig it up to see if what i think is the problem, really is the problem. so i was thinking that the prob was that the slave cylinder wasnt pushing the fork all the way. so i put a nut between the slave cylinder and the fork and now it works. so the problem was that the cylinder isnt pushing all the way. i dont want to leave it riged like that. so what do you think the problem is? thanks for all your input.
oh, and everyone that said look for leaks, there are not leaks in the system. i have been constantly checking for leaks because when i first looked my fluid was way below low. but it is staying constant now and i dont see any leaks. thanks again for your input.
:slap:
If it's an internal master cylinder leak you won't see anything sometimes...it will leak by the seals and stay under the carpet
umm so you don't think the slave cylinder isn't bad because why?
'00 Dakar Bus CRS Edition
LCD Squad #0001
LCD Squad #0001
Originally Posted by WiLL
Time for a new slave cyl.
