picture taking advice for a noob
Old Jun 26, 2005 | 07:09 PM
R_Squared's Avatar
R_Squared
LEVEL UP
Default picture taking advice for a noob
I could really use some advice on how to take better pictures, mainly night shots. I took a bunch of shots tonight that I thought would turn out really good when I framed them, but then when I actually took the pictures and looked at them on my computer, they look awful. Blurry, out of focus, you can see a reflection from the flash. Any advice on what settings I should use or anything like that? I only have a 3.2 megapixel Olympus Stylus 300 but I know I should be taking better shots than this! Thanks for any help.
File Type: jpg
File Type: jpg
Old Jun 26, 2005 | 07:12 PM
wagon89's Avatar
wagon89
1/3rd rule
Old Jun 26, 2005 | 07:15 PM
Cosmo M3's Avatar
Cosmo M3
Lurker
tripod > j00
Old Jun 26, 2005 | 07:23 PM
MPerson's Avatar
MPerson
For night shots, set it on a high ISO, and try to use a tripod or something to rest the camera on.
Old Jun 26, 2005 | 07:24 PM
firebane's Avatar
firebane
Basically everyone will tell you the 1/3 rule but I say shoot how you feel and take whatever you want. You'll want a tripod for stability and use lower exposure rates.
Also if you are real serious about photography invest in a good flash.
Old Jun 26, 2005 | 07:30 PM
R_Squared's Avatar
R_Squared
LEVEL UP
as stated above, i am a photo taking noob. so what's the 1/3 rule? also, what is an ISO? btw, i resized those 2 pics from 2048 x 1536 to 800 x 600 after i loaded them onto my computer. does that make a big difference as far as the clarity of the picture?
Old Jun 26, 2005 | 07:46 PM
firebane's Avatar
firebane
http://en.mimi.hu/photography/iso.html
Basically the higher the ISO you set the grainier the picture. You'll probably have to put your camera into Manual mode for it to be able to change. Everyday pictures are shot at usually 50 ISO where night shots are usually done at 400+ ISO depending on camera.
1/3 rule
http://www.shutterfreaks.com/Tips/RuleOfThirds.html
Old Jun 26, 2005 | 08:18 PM
LT's Avatar
LT
The deer had to die!
we should have a write-up on proper ways to photograph our cars in different lighting/settings
Old Jun 26, 2005 | 08:24 PM
19.3secS2K's Avatar
19.3secS2K
my bum is on the swedish!
don't use the flash on the camera
Old Jun 26, 2005 | 08:29 PM
white_n_slow's Avatar
white_n_slow
it's my D in a B
yeah... its pretty much impossible to get a good night-time exposure that isn't blurry without a tripod. If you don't have a tripod and you're cheap, you can also try balancing the camera on another stable object (i.e. another car, a fencepost, even your knee if you're careful). Another trick that sometimes turns out well for car photography is to set the camera on the ground and then stack nickels under it so its tilted up to frame the car properly. Read up on the basics, look at pictures you like and try and mimick them, and keep practicing.
