HELP: Engine Smoking
A Philanthropical Fruit
I need some quick advice from those who know might be familiar with this topic. My engine (stock 1998 Prelude) is smoking. I did an oil change today, and I'm pretty sure it has something to do with that.
I tightened the bolt correctly, put on the right filter, used 5w-30 oil, and closed all seals well.
The smoke appears to be coming from the intake manifold, or something underneath it. This is near the oil filter. Could it be, that I spilled some oil when replacing the filter, and it's being burnt on the hot exhaust piping?
Also, could too much oil be the problem?
Please help! Thanks guys.
You probably spilled some oil somewhere or your greasy hands touched the exhaust piping. As long as oil isn't gushing out and around the filter because the gasket came off the old filter, you're fine.
Yes, it's probably that, because when I take off my filter, alot of the oil spills onto the axles and the exhaust. How about leaving the car on while it's jacked up, and look under the car to see if the smoke is coming off of the exhaust.
its probably just spilled oil.
too much oil in the engine wont make it smoke, it just increases the chance of blowing out the gaskets.
if all else fails...
So kids, when you perform a swap, always have a friend that has had at least 8 hours of sleep check your work when you think you're "done".
Incorrect.
1. VTEC always engages at a specific RPM
2. The vehicle has to moving over a certain speed. IE you cannot engage VTEC while revving in neutral.
3. Coolant temperature must be over 60c.
4. ECU must not be in limp mode.
