HELP: Engine Smoking
Old Jun 8, 2005 | 10:35 PM
Samson's Avatar
Samson
chris is the devil
i think the engagement "feel" of vtec can vary... leading you to believe its happening at different times.
Old Jun 8, 2005 | 10:41 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Have you also checked for any leaks from the oil pressure sensor?
Old Jun 9, 2005 | 12:38 PM
beier's Avatar
beier
A Philanthropical Fruit
Oil pressure and RPMS are usually directly related. I think the tach works off of oil presure, in fact.
Well, I think my oil problem is solved, if that matters
Old Jun 9, 2005 | 01:07 PM
ED9man's Avatar
ED9man
driver
Originally Posted by umop-apisdn
Incorrect.
1. VTEC always engages at a specific RPM
2. The vehicle has to moving over a certain speed. IE you cannot engage VTEC while revving in neutral.
3. Coolant temperature must be over 60c.
4. ECU must not be in limp mode.
Mine seems to vary though. :dunno:
I am pretty sure it used to engage a little over 5000, now it engages a little below 5000, and it'll change sometimes. Is the tach signal for the ECU the same as for the gauge?
Old Jun 9, 2005 | 01:08 PM
umop-apisdn's Avatar
umop-apisdn
Allergic to vitamin D
Tachs do not receive their signal from oil pressure :rofl:
Old Jun 9, 2005 | 01:12 PM
ED9man's Avatar
ED9man
driver
:eh: I wasn't talking about oil pressure. I was talking about the tach signal. Because if the guage seems to be accurate but the VTEC point is varying maybe it has something to do with the ECU's tach signal, if it is a different one, which it probably isn't. :dunno: But if the ECU's signal was not accurate thent the tachometer would probably read a varying fuel cut off too which it doesn't so it must be something else.
Old Jun 9, 2005 | 01:27 PM
beier's Avatar
beier
h: I swear I remember learning that somewhere.
