wired + wireless home network
Get rid of the wired router. Connect a 10/100 switch to the wireless router and connect all your wired devices to that. Configure them to use 10.0.0.x IP addresses and the subnet mask 255.255.255.192. Set the gateway to 192.168.1.2 and manually add as many DNS servers as you want.
I think this procedure should give you the result you want, although I still don't understand why you want it.
Originally Posted by joebenz
i dont see how you can prevent access to either router when everything is on the same physical network. only way i can possibly see that work is with VLANs, and i know your routers/switches dont have that.
so with that said, everything sounds normal except not being able to ping from client to client...unless you have firewall turned on on clients.
