Engine noise question.
Old Apr 28, 2005 | 07:31 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
exactly.
Old Apr 28, 2005 | 07:32 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
thats why i was fishin for more info
Old Apr 28, 2005 | 10:59 AM
flyromeo3's Avatar
flyromeo3
Originally Posted by click sidious
oh. and some foil wrap will help with that just fine.
hmmmm......
Monster twisted/shield rca's
Sony XAV 7W head unit
Audiobahn A400T 50x4
Audiobahn A800T- 800watts 2ohm continous
Kicker L5 12' solo baric
ground cable is about 3-4 feet in length
i used some electrical tape to tape off some of the 12v wires that are in there.
Needless to say that did work but, it only limited the noise.
I guess Ill just take out the whole rack and run the speaker wires around the other side.
Thanks for your help guys.
felipe
Old Apr 28, 2005 | 11:01 AM
DakarM's Avatar
DakarM
are you talking about alternator whine? if so, find a better ground and/or use a common ground.
'00 Dakar Bus CRS Edition
LCD Squad #0001
Originally Posted by WiLL
Old Apr 28, 2005 | 11:04 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
and make sure your wire is big enough. what gauge wire is the ground (i sound like a broken record)
Old Apr 28, 2005 | 11:09 AM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
just simply wrap some metal foil around each of the wiresabout a foot in either direction from their closest point, and make sure the metal foil doesn't touch from each wire.
I run both my power and signal cables along one side of the car without a problem. But I'm only running one 400watt amp.
In my old accord though, I had the same setup. But the signal cable ran right over the power for the rear wiper. I just wrapped the power wire for the rear wiper (or whatever one it was) in foil wrap and the problem was solved.
It's just a problem of shielding, grounding, and insulation.
Old Apr 28, 2005 | 11:46 AM
XScarAudio's Avatar
XScarAudio
///o\\\///o\\\
i think he needs a flux capacitor. <doc brown> ONE POINT TWENTY ONE GIGAWATS </doc brown>
