How long do car batteries usually last?
Old Jan 6, 2005 | 03:28 PM
flyromeo3's Avatar
flyromeo3
Originally Posted by HAN Frodo
mine has 108k miles on it. I guess i should get it tested.
yeah...the northeast is brutal when cold starting a car.
Old Jan 6, 2005 | 03:41 PM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
Howto? It's pretty easy.
Don't stand in water when doing it
Remove the negative battery terminal first. make sure that doesn't flip back and touch the terminal... that can be bad :rick:
Next remove the positive terminal. Remember that the whole ground and pretty much everything metal under the hood is negative/ground sooo it's generally a good idea not to touch anything AND the positive terminal at the same time.
Once those are both off... you will probably need to remove some sort of battery tie down. It's usually just 2 nuts or screws.
Lift the battery out, not by the terminals though. If it's got a battery cover around it, take that off and put it on the new one. Then just reverse the process. Battery in. Connect the positive. Then last the negative.
Old Jan 6, 2005 | 03:49 PM
Samson's Avatar
Samson
chris is the devil
what causes sparks to fly? because i remember watching someone and that happening... something i dont wanna do
Old Jan 6, 2005 | 04:00 PM
Mandi's Avatar
Mandi
That's REALLY good. Mine died somewhere around 80k...in the winter.
Old Jan 6, 2005 | 04:04 PM
joebenz's Avatar
joebenz
nelson rules
switching positive and negative
no sig
Old Jan 6, 2005 | 04:49 PM
AcuraFanatic's Avatar
AcuraFanatic
If you can't change a battery or an air filter, you should not own a car.
Old Jan 6, 2005 | 04:57 PM
Samson's Avatar
Samson
chris is the devil
well i can change my air filter. i cant do much.. but i do change my own oil, rotate own tires etc.... just never had to change a battery...
Old Jan 6, 2005 | 07:24 PM
CivicSiRacer's Avatar
CivicSiRacer
Honorary Moderator Alumni
MOst batteries last about 5 years or about 2 completely killed times.
Autocross Help Page
Old Jan 6, 2005 | 07:25 PM
dubcac's Avatar
dubcac
I
Or touching the postitive and negative terminals together with a wrench.
Old Jan 6, 2005 | 07:31 PM
2gr84u's Avatar
2gr84u
2gr84u
I did that a while ago well putting in battery on my Laser heh it tack welded the bolt to my ratchet and burned the **** out of my hand
