wireless connection probs at home....doh
Old Dec 30, 2004 | 01:40 PM
reech-around's Avatar
reech-around
RIP Woong.
Default wireless connection probs at home....doh
add me to the list of people with wireless probs h:
i moved to a new place, and my only option is wireless. i havent had trouble connecting before, but today it just won't work. fyi, it's an unsecured network. in the past, i have also connected to my neighbor's unsecured network :rick:
what i'm using:
desktop with a USB wireless adapter
laptop with a cardbus adapter
basically, my wireless adapters can "see" the router, but can't connect to it. the networks are available, but i cant access them
any ideas?
thanks
clickwir's Avatar
clickwir
Floppy Death! noES!!!
I'll be right over...
Old Dec 30, 2004 | 01:41 PM
Discosmurf's Avatar
Discosmurf
3G Integra Aficionada
:werd: The EXACT same thing is happening with my roommates' and mine.
Verizon came out and said that it's being read as working, yet, we can't get anything. She has a wireless modem from Verizon and a D-Link router and I have just the D-Link network card.
94civicEX's Avatar
94civicEX
I got worms.
Did you choose to allow yourself to connect to it?
99 Integra GSR
06 TSX
duck squad member #00003
Old Dec 30, 2004 | 01:45 PM
reech-around
RIP Woong.
yeah...i told it to let me connect, even though it's unsecure :happysad:
Old Dec 30, 2004 | 01:46 PM
94civicEX's Avatar
94civicEX
I got worms.
Hmm, try 192.168.1.1, what happens.
Start; Run; Cmd; tyep: ipconfig /all hit enter, does it say crap?
99 Integra GSR
06 TSX
clickwir's Avatar
clickwir
are you getting an IP?
Old Dec 30, 2004 | 01:49 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Those were my suggestions! :madfawk: :reechy:
Also, what connections do you have enabled in you Network Connections control panel?
Old Dec 30, 2004 | 01:56 PM
reech-around
RIP Woong.
ok...ill try 192.168.1.1 when i get home..
i tried "ipconfig /all" - it listed some crap, but the main thing i noticed was that my wireless adapter was labeled as "disconnected" - but under USB properties, the adapter is working fine
didnt check :doh: IP from the router?
:reechy:
i dont remember what i have enabled in the Network Connections control panel...what should i look out for?
the thing that confuses me is that i havent changed any of my settings from last night, when it worked fine
Old Dec 30, 2004 | 02:02 PM
Epoch's Avatar
Epoch
Maybe the wireless network you're peeking at doesn't support DHCP reolution? Whenever I have set up a residential wireless network that is off my access, I turn off DHCP resolution and manually assign IPs, beyond just using a WEP key... That way I can keep the whole broadband-leech thing from destroying my browsing... is this a legit wireless point, or something you're attempting to... I don't wanna say hijack, so I'll say; borrow?
:reechy:
Make sure that you aren't trying to do something crazy like connect over 1394... I would right-click, disable any connections you don't plan to use. then I would double click the wireless connection and tell us what you see there exactly
