Computer Problems
Old Dec 17, 2004 | 05:00 PM
Default Computer Problems
I seem to be having a problem. When i start my pc im getting a computer error signal frequency is outta range please adjust signal timing. I tried a different video card and it gave me 1 long 3 short. When i turn the monitor off and on i get a different signal read out. If anyone could help A.S.A.P that would be greatly appreciated
Old Dec 17, 2004 | 05:05 PM
MPerson's Avatar
MPerson
So the computer's monitor is going into idle. Maybe your power source went out, that's what i'm betting it is.
Old Dec 17, 2004 | 05:11 PM
The power source for what though?
Old Dec 17, 2004 | 05:22 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
actually Jae was asking the question for me,...im getting a black screen with a red box,..inside the box it says
Attention
SINGAL FREQUENCY
IS OUT OF RANGE
CHANGE SIGNAL
TIMING
25.8KHZ 58HZ
and those numbers usually decrease to 20.1 and 47
Old Dec 17, 2004 | 05:24 PM
94civicEX's Avatar
94civicEX
I got worms.
Ooooh, okay, now I understand.
Try switching monitors.
Do you have an S-Video running into it or anything? Are you able to even boot? When is it happening exactly?
99 Integra GSR
06 TSX
duck squad member #00003
Old Dec 17, 2004 | 05:32 PM
H-Accord-22's Avatar
H-Accord-22
Duh
did you just changed to another monitor or something? usually, it's because of the monitor that's not supporting the refresh rate set by your graphic card. Try to switch to another monitor and set the reresh rate and resolution so that it'd be compatible with this monitor. However, I believe that the usual lower refresh rate is 60hz, current monitors are supporting 75hz+. Your monitor seems to be out of date though. So in another word, you monitor is going bye bye.
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
fawker like i know what a S-video is,...ill break it down somemore for you
whenever i use the original video card that came with this PC im fixing,...it gives me that red box,..when i take that video card and put it in my PC,..everything is fine,...so i took my video card and put it in the messed up PC and i get one long beep and 3 short beeps and nothing comes on the screen ,...can you follow what the hell im saying?? cause i just lost myself a couple times h:
Old Dec 17, 2004 | 05:34 PM
94civicEX's Avatar
94civicEX
I got worms.
Make sure the video card is in the right slot, pushed in all the way.
99 Integra GSR
06 TSX
Old Dec 17, 2004 | 05:35 PM
WideBodyEK's Avatar
WideBodyEK
Stage 3 Modified
it is in the right slot cause there is only one slot to push it into,..and yes i checked if it was pushed in like 4 or 5 times ,..help!!!!
94civicEX's Avatar
94civicEX
I got worms.
Switch the monitor.
99 Integra GSR
06 TSX
