Honda vs. Toyota's Variable Valve Timing
Old Sep 24, 2004 | 02:15 PM
Cosmo M3's Avatar
Cosmo M3
Lurker
Default Honda vs. Toyota's Variable Valve Timing
My roommate and I were talking about his Scion tC and he wanted to know the difference between the following and could you please explain what they do?
Toyota's VVTi and VVTL-i and Honda's VTEC and i-VTEC
Old Sep 24, 2004 | 02:16 PM
qtiger's Avatar
qtiger
They vary valve timing.
Old Sep 24, 2004 | 02:18 PM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
Well I'll share what I got... Honda VTEC is the ability to switch to 2 diffrent CAM profiles, one for low rpm and one for high rpm. i-VTEC impoves upon that with, I believe, continual variable of the CAM profiles through the RPM range.
Old Sep 24, 2004 | 02:21 PM
bluetwo's Avatar
bluetwo
Relevance is irrelevant
I read about it once. And I believe that toyota does more with the air flow. Variable intake something or other.
Old Sep 24, 2004 | 02:23 PM
FDragger's Avatar
FDragger
the F is a secret :shhh:
they are almost the same. lots of car manufacturers have VVT variable valve timing. is one better than the other? theres no yes or no answer. VVT can be used to save gas or in other cases waste it.
Old Sep 24, 2004 | 02:24 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
VVTi is similar to VTEC
VVTLi is similar to iVTEC
...to the best of my knowledge
Old Sep 24, 2004 | 02:25 PM
Kestrel's Avatar
Kestrel
Push to shock!
VVL (predecessor to VVTL) and VTEC are similar. i-VTEC and VVTL-i are similar. They're not all that different from each other.
Old Sep 24, 2004 | 02:37 PM
TheOtherDave™'s Avatar
TheOtherDave™
Apathy Kills
Here's what I remember.
VVT - i advances or retards the camshaft only. It does not switch cam lobes at any point in the rev band.
VVTL-i is truly akin to our i-VTEC.
It advances and retards the camshafts, and the camshafts have a secondary cam profile, to which it switches at around 6k rpm in most applications.
The mechanics of how the switch takes place are subtly different from the system Honda uses, but the basics forces are pretty much the same.
h: There ya go.
Old Sep 24, 2004 | 03:06 PM
bluetwo's Avatar
bluetwo
then who is it that varies intake pressure?
am i retarded?
Old Sep 24, 2004 | 03:09 PM
Kestrel's Avatar
Kestrel
Push to shock!
Actually IIRC either the GSR or the Type-R have some sort of variable intake manifold.
