is auto > manual?
Old Sep 6, 2004 | 01:28 PM
AP2's Avatar
AP2
Moderator Alumni
Originally Posted by brtecson
I suppose you are the expert on the subject then... What do you think about those tilton carbon clutches on a 6spd mt supra tt?
Those are the messiah of clutches. They're working very well with the Supra guys and the Honda guys with big power.
Old Sep 6, 2004 | 03:29 PM
Josh M's Avatar
Josh M
I am by FAR not an expert I like the Tilton clutch. When I drove a big single car with it it felt pretty good. More of the supra guys though are now switching to the RPS Carbon/Carbon and the WOTM II clutches.......hold more power and are way more slippable and streetable. The tilton is also noisy as hell........it seriously sounds like the car is going to shake to pieces damn POS Supras
Old Sep 6, 2004 | 03:32 PM
Josh M's Avatar
Josh M
Originally Posted by ED9man
automatics are heavier, break more, and suck more power than manuals
I dunno about that one......a lot of people I know who regularly race tend to fuse their clutches to their flywheel.......this is probably due to using a lightened flywheel so there is less rotational mass. Automatics are heavier that is true......not sure about breaking more though......they might suck more power but they also transer the power a lot better.
Old Sep 6, 2004 | 03:45 PM
b00gers's Avatar
b00gers
Originally Posted by xsentrixsupra
When u have a built auto they don't recommend doing the manu shifting as I guess it has set line pressures and the manu mode messes with it.......I am no transmission expert........although I am ASE certified to work on them but when I bought my transmission they said don't use manual shifting anymore
What if you have a stock auto tranny? I don't shift mine manually, but on occasion I am forced to slap it into D2 to keep the revs up so my all mighty b18 can make it up steep hills.
Old Sep 6, 2004 | 05:53 PM
Josh M's Avatar
Josh M
That should be fine if its stock.......you use it for what it was meant to be used for. You should be ok
