Workout Crew *Help*
Old Aug 22, 2004 | 12:57 PM
96JdmAccord's Avatar
96JdmAccord
Im So JDM
Default Workout Crew *Help*
Hey,
So I weigh about 185 and stand about 5'8 or 5'9. Im trying to lose weight and get more fit so I can move up in lacrosse. I usually work out 2-3 times a week doing 12 minutes of paced running which is about 1.25 miles and work out for about 45 minutes of weight lifting. If I want to lose more weight and be in the 165ish range should I change the way I run? Maybe do sprints and such? This is on a treadmill by the way. I mean im decently in shape as my arms are pretty defined I just want to improve my chest, stomach, and get faster. I havent worked out for about 5 weeks because of traveling but im going to get back into it now.
So whats your recomendations on my running and weight lifting? I also wanted to know if you guys recomend those pills that fast up your metabliosm and slow down your need for food? Forgot the name but It has been mentioned before.
Thanks
Jon
Old Aug 22, 2004 | 01:49 PM
redgoober4life's Avatar
redgoober4life
I eat plastic.
If you're playing lacrosse i think you want to run for longer then 12 minutes. I would guess that endurance would be a good thing.
Oh, and those pills are, well...they're a short cut. Have some pride and do it all on your own, you'll feel better about yourself in the end.
Old Aug 22, 2004 | 01:51 PM
ManInCamo's Avatar
ManInCamo
Old School Crew
yea, do at least 45 minutes of cardio when do cardio...
start running two miles, then hop on an eliptical machine, then try running 2.5 miles, etc...
get at least 45 minutes of cardio.
Old Aug 22, 2004 | 02:30 PM
redgoober4life
I eat plastic.
This is what I do. It breaks up the boringness sometimes.
edit: get on the bike after for about 10 minutes, it's good to ease your heart down, and not spike it, when you're trying to strengthen your heart.
Old Aug 22, 2004 | 04:21 PM
brtecson's Avatar
brtecson
pukimonster
I find that the best way to drop pounds by exercise is by doing cardio that uses more than just your legs, ie swimming. Although, if you don't have the endurance to swim for 45 minutes straight, I wouldn't do it. It takes lungs of gold to swim hard for 45 minutes.
I heard rowing is pretty intents too, but I haven't tried it.
Also, as stated above, aviod monotony. Do a different cardio routine for each day of the week that you do cardio. You may also want to do cardio and weightlifting on different days, because they counteract eachother a little bit.
Old Aug 22, 2004 | 04:26 PM
redgoober4life
I eat plastic.
I do a little bit of cardio on my lifting days. Probably 10 minutes on the bike just so I'm not stiff as a brick.
