help with explorer and wmp
Old Jan 23, 2004 | 01:24 AM
Nightshade's Avatar
Nightshade
un-Touch'd krew
Originally posted by Grifter
i dont want the media player preview
Only way to do it is to go back to classic
Old Jan 23, 2004 | 08:38 AM
flipped cracka's Avatar
flipped cracka
BOOM goes the dynamite!
i think it'd be the other option. the web view, not active desktop.
Old Jan 23, 2004 | 10:09 AM
Grifter's Avatar
Grifter
the web view takes the whole thing away
i just want the media player preview gone
o well :sad:
Old Jan 23, 2004 | 10:23 AM
sxecrow's Avatar
sxecrow
Banned
just install Winamp and play the entire directory. You'll be much happier with Winamp.
Old Jan 23, 2004 | 10:24 AM
Grifter's Avatar
Grifter
i have winamp but that doesnt take care of the problem
Old Jan 23, 2004 | 10:54 AM
flipped cracka
what version of windows do you have?
Old Jan 23, 2004 | 11:15 AM
flipped cracka
eh, i guess it doesn't matter. here's your answer. find folder.htt (a hidden file in either in C:\Windows\Web or C:\WINNT\Web) and open it in notepad (or your favorite text editor). find the line that has
else if (IsSoundFile(ext))
(probably around line 182) and delete everything from that line (including that line) down to right before
if (Preview.innerHTML != "")
then save the file somewhere else, where you can find it (like C:\ ) and then copy it to where you found it originally. make sure you save a backup copy (just in case). that should do it. worked on my machine with Windows 2K.
Grifter's Avatar
Grifter
2kp
Old Jan 23, 2004 | 11:19 AM
Grifter's Avatar
Grifter
eh, i guess it doesn't matter. here's your answer. find folder.htt (a hidden file in either in C:\Windows\Web or C:\WINNT\Web) and open it in notepad (or your favorite text editor). find the line that has (probably around line 182) and delete everything from that line (including that line) down to right before then save the file somewhere else, where you can find it (like C:\ ) and then copy it to where you found it originally. make sure you save a backup copy (just in case). that should do it. worked on my machine with Windows 2K.
ill check when i get home!
