Remote connection to my computer, how?
Old Oct 21, 2003 | 02:49 PM
Epoch's Avatar
Epoch
CHRISTMASTIME IN IRAQ
Here's what the Virtual Server looks like on my router (attached).
Find out if the builtin Microsoft VPN app accesses over TCP or UDP (or both), and which port (or ports). Then, all you do is enter your comp's specific IP address into the associated box, and hit "apply".
I have an Xsense, but Linksys are just as good, and should have a similar interface.
File Type: jpg
Old Oct 21, 2003 | 02:55 PM
yellowbastard's Avatar
yellowbastard
Bootyologist (__i__)
There are also programs out there that you could use. I use SMS and Radmin at work to connect to other machines. You have to have the other machine setup and installed with the client in order to properly connect. For example when I use Radmin I have the end user click on a Batch file I have setup on one of our Public drives. I have it configured so that when they do that it generates a text document with their IP address and computer name. It also installs the client stuff needed and removes it from their machine when I close it.
Old Oct 21, 2003 | 03:06 PM
mike01civic's Avatar
mike01civic
Well if you just want to transfer files an FTP server set up on a secure box will do just fine. I found this to be most useful when working in the lab on programs and being able to shoot them right over to my box where i know they'll be safe.
Old Oct 21, 2003 | 08:42 PM
Nelson's Avatar
Nelson
Administrator
Real VNC is easy to use
9Y0 Cayenne GTS
E46 ///M3
YD4 MDX
- SOLD
EG Ferio - SOLD
FA Ferio - Returned
www.NelsonLee.net
Old Oct 21, 2003 | 09:48 PM
H-Accord-22's Avatar
H-Accord-22
Duh
i need to learn more about this networking. So basically can I access the programs at the comp at home such as flashget, etc- using my laptop at school - to set it up to DL files even i'm away?
Old Oct 21, 2003 | 09:54 PM
clickwir's Avatar
clickwir
Floppy Death! noES!!!
uhh. All you need is port forwarding. I wouldn't recommend the DMZ trick... too much of a security risk.
Just open the port(s) that XP's remote access needs on the linksys router and point them to your internal machines IP.
Then when you're somewhere else on campus, just put in the IP and there you go.
