powerpoint help needed!!
Old Oct 8, 2003 | 10:27 PM
RB26DETT's Avatar
RB26DETT
Eagles > NFL
Default powerpoint help needed!!
ok, i have this picture i want to use for the background for every slide. how do i make the pic the background?
Old Oct 8, 2003 | 10:47 PM
RB26DETT's Avatar
RB26DETT
Eagles > NFL
i reeeeeeeeaaallllyyyyy need help
Old Oct 9, 2003 | 06:02 AM
Brad's Avatar
Brad
wooo nascar!
did you figure it out yet?
first of all.. which version of ppt are you using?
Old Oct 9, 2003 | 08:30 AM
well ... what i do when i make slides is ...
make 1 page first, then copy it to make page 2 ... that way the background sticks. let me see if there's another way to do this if the slides are all made.
brb ...
Old Oct 9, 2003 | 08:33 AM
If you want to apply the change to selected slides only, select the slides in normal view. Otherwise, the change applies to all slides that follow the design template of the currently selected slide.
On the Format menu, click Background.
Under Background fill, click the arrow on the right of the box, and then do one of the following:
Select a color from the color scheme
Click one of the eight colors displayed.
Select a color outside the color scheme
Click More Colors.
Click the color you want on the Standard tab, or click the Custom tab to mix your own color, and then click OK.
Select a fill effect or picture
Click Fill Effects, and then do one of the following:
To use shading, click the Gradient tab, click a type under Colors, click a shading style, and then click OK.
To use a texture, click the Texture tab, click the texture you want or click Other Texture to select a file and insert it, then click OK.
To use a pattern, click the Pattern tab, select the pattern you want, select foreground and background colors, then click OK.
To use a picture, click the Picture tab, click Select Picture to find the picture file you want, click Insert, and then click OK.
Use the background fill from the slide master
Click Automatic.
Do one of the following:
If you want to apply the background to selected slides, click Apply.
If you want to apply the background to all slides, click Apply to All.
Old Oct 9, 2003 | 08:38 AM
mike01civic's Avatar
mike01civic
RTFM
Old Oct 9, 2003 | 08:40 AM
okay ... found it ...
format
background
"fill effects" from the drop down
then the "picture" tab
select picture and click ok
then click apply to all
Old Oct 9, 2003 | 08:41 AM
Originally posted by mike01civic
RTFM
