00 EBP Civic si and past rides
Alright yall here is my current ride a 2000 Honda Civic Si which is mostly stock excpet for a AEM CAI, short throw shifter w/ urethane bushings, type-r shifter, gutted cat, alarm system, crappy tint(which i wanna replace), 16" Rota Circuit 8's..here are some pics...i'll also show you some of my old rides ive had...
my ride before that was a 2000 Acura Integra GSR which i only have pics of it when it was stock but i had put on a 4-1 header, test pipe, 2.25" exhaust piping w/ glass pack aka resonator and a black chrome tip)sounded swett like a srt-4 or boxer motor), short throw shifter and luminics pure blue headlight bulbs but spun a rod bearing after only having it about 2 months..so i sold it..
what ugly tail lights...
then before that was a 2002 Honda Civic Si that i put on a flowmaster 60 series muffler, shifter stabilizer bushings...can you tell i like a firm shift and positive response
....Injen RD CAI, blacked out housing head lights and smoked taillights, rear lower tie bar, greddy counter weighted shifter
i absolutely love the rally style shifter on the dash!!
Then before that was a 1994 Honda Accord that looking back i would have done things a little diff.(ok maybe alot diff.) and not have sold it after dropping $8k+ into it. Here iit is a 1994 honda accord ex. It came with a meager 2.2 vtec motor that made 145hp/147tq. I did the small things first Bomz cold air intake, Venom 400, front strut tower bar, lowered 2" and put on camber corection kit. Went through various tail light and head lights and ended up with JDM black head lights and carbon fiber tail lights. Put on a full exhuast w/ obx ceramic coated headers, hi floe cat and 2 1/2" pipe to a titatium muffler. A invader style air dam. I had a type-r carbon fiber wing from Japan that i put on. I had a great stereo system that had a pioneer deck with pioneer 2 4 1/2" and 6''x9'' w/ 2 polk MOMO subs and a stinger 1 farad cap and 1200 watt audiobahn amp. I eventually put a full airbag suspension with one compressor and five gallon tank and eventually added a second comp. The last thing i did was get a vented carbon fiber hood from Japan as well.
Completely stock...
About 1 1/2 years later and $8k+
My own custom stereo setup....
Slammed
And last but ceratainly not least is my 72 chevelle which i loved...but i drove it VERY HARD. It had 350 small block w/holley 650fm carb, open air element air filter, electric fan, edelbrock performer rpm intake, mild cam, headers w/ 2.5 piping and flowmaster mufflers and chrome tips, msd hi performance distributor and pulg wires, turbo 350 transmission 3 speed automatic.
and yes it is a 4 door sedan...
Completely stock...
Slammed
never ever put an air-ride set up on an honda or acura. not meant for those cars man. just looks stupid. the accord you had was ok looking but the air-ride shit just ruined it for me man, no offense or anything but i guess you like it. just dont go and put it on the civic, its a nice car just the way it is.
air ride suspension when you have all the electronics to properly dial the suspension in can be one of the most effecient suspensions..they use them on rally cars and some drag cars will use them in the rear.....
but no im not gonna put them on my EM1....like i said there are things i would have done differently now on my accord...
as far as the EM1 plans here is a list....i always make a list of what i want to do to my car....like a set of goals if you will...looks is gonna be much more subtle the focus is perf.....
2000 Honda Civic Si Goals
Approximately 300hp/ run 12’s in the ¼ mile
Engine: B16A2
-Royal Purple oil
-Hasport Motor Mounts
-Low compression (9:1, 8.5:1) forged pistons
-Forged connecting rods
-Aftermarket sleeves
-ARP head studs
-ITR cams or aftermarket cams
-ITR valve train or stiffer/dual springs, titanium retainers, ss valves
-ITR intake manifold/aftermarket manifold port matched to head
-ITR throttle body/after market throttle body port matched to IM
-High flow fuel rail
-Fuel pressure regulator
-Fuel injectors (750cc?)
-Iridium tip spark plugs (NGK)
-Aftermarket spark plug wires
-MSD cap and rotor
-External coil/ignition system
-T3/T4, GT30R ball bearing turbo and turbo setup..actually almost 100% going with a GT35r (Full Race)
-Neptune Tuning system
-3” exhaust (Thermal)
-Koyo Radiator
-Lower degree thermostat and fan switch
Suspension:
-Approx. 2” lowering springs (Eibach, Tein, Skunk2)
-Bilstein Struts
-Camber correction kit
-Aftermarket front and rear sway bars w/ urethane bushings
-Aftermarket front control arms
-Aftermarket rear lower control arms
-Aftermarket front strut bar (Mugen)
-Aftermarket rear strut bar (Mugen)
-Full Race traction bar system
-Energy Suspension urethane bushings kit (for all of suspension)
-Brembo Cross-drilled and slotted brakes F&R
-Aftermarket brake pads (ceramic)
-SS braided brake lines
-Motul brake fluid
Transmission:
-ITR transmission w/ factory LSD
-Stage 4 clutch
-SS braided clutch line
-Redline transmission fluid
-ATS 4.93 gear kit ?
Exterior:
-CF vented hood
-CF trunk
-CF grille
-CF mirrors
-CF? spoiler
-Lip / body kit
· Front lip/ air dam
· Side skirts
· Rear lip/ rear bumper
-Fix dents
-Re-paint whole car EBP
-Smoke taillights ?
-CTR headlights
-HID kit
Interior:
-CF bezel (CTR)
-Interior lights ?
-CTR door panels
-CTR or other aftermarket front seats
-Re-upholster/ replace rear seats
-CTR (cf) climate control
-CTR center console/ re-upholster stock
-CTR steering wheel
-CTR shift boot
-CTR sun visors/ re-upholster stock
-CTR carpet/ custom
-CTR floor mars/ aftermarket
-Custom Headliner
-New window tinit
-High output cd deck
-Replace component speakers
-4 channel amp for components
-Sub woofers (JL W1 series 12”)
-Mono amp w/ 0 gauge amp kit
-Capacitator
Engine Dress Up:
-Samco radiator hoses
-Silicone lines
-Mugen reservoir covers
-Mugen oil cap
-Mugen / CTR valve cover
-Spark plug cover (CF)
-Oil catch can ?
-Oil filter re-location kit ?
i may or may not do all these things but its a start..the finish project could be completely diff. Im not one of those people that just huff and puff and say im gonna do something but never do(which you can see from my accord....started out completely stock).....as long as i actually have this one a couple years i'll accomplish what i wan too...all the other cars i just didnt have long enough to do what i wanted....thanks for the comments
Engine: B16A2
-Royal Purple oil
-ARP head studs
-MSD cap and rotor
-Koyo Radiator
Suspension:
-Bilstein Struts
-Motul brake fluid
Transmission:
-Stage 4 clutch
Exterior:
-CF vented hood
-CF trunk
-CF grille
-CF mirrors
-CF? spoiler
-Lip / body kit
· Side skirts
-Fix dents
-Smoke taillights ?
-CTR headlights
-HID kit
Interior:
-CF bezel (CTR)
-Interior lights ?
-CTR door panels
-CTR steering wheel
-CTR shift boot
-CTR carpet/ custom
-Custom Headliner
-New window tinit
-Capacitator
Engine Dress Up:
-Silicone lines
-Mugen oil cap
-Oil catch can ?
A lot of that crap you have planned is a waste of money. CF wire cover? Why? No wire cover weighs nothing. Oil cap, resevoir covers? Aftermarket control arms? Ceramic pads suck, well I mean if you drive seriously at all. Camber correction? Why not take the gain, the whole point of lowering it is to make it handle better, just take some out of the rear with washers.
yay but 300hp is only for the initial turbo setup....if i build the motor i'll have a low(12psi or so) and high(20+psi) boost setting and will shoot for around 500+whp if i build it which i know wont be a problem
