neon installation
Old Mar 20, 2006 | 05:34 PM
hcivicdx96's Avatar
hcivicdx96
Default neon installation
how would u go about installing neons (correctly and hidden) on the front, back, and sides of my 96 honda civc dx
Old Mar 20, 2006 | 05:45 PM
VTEC-Power's Avatar
VTEC-Power
You don't, they are illegal.
Old Mar 20, 2006 | 07:33 PM
zip ties are ur friend... other than that its pretty straight forward just follow the directions that should have came with it
Old Mar 21, 2006 | 02:14 AM
InfiniteVTec's Avatar
InfiniteVTec
The Dealer
It might be easier done with a body kit on the car
Old Mar 21, 2006 | 04:26 AM
The best way to install neon is not to install it at all.
Old Mar 21, 2006 | 07:31 AM
Mynard's Avatar
Mynard
Eye warship say ten!
:werd: They are ricealicous!
Old Mar 21, 2006 | 08:19 AM
Kai's Avatar
Kai
Rotorphile.
I hope you change your own oil, I've seen neons get crushed at work. They make a very satifying crunch.
It's not our problem if the customer didn't tell us they were there. :chuckles:
Old Mar 21, 2006 | 09:59 AM
cobbcustomz's Avatar
cobbcustomz
trying to attach them under the car without a bodykit all while hiding the tubes is not likely. you will clearly see the tubes and they look like crap when visible. And be prepared they will break I had mine on for several months before hitting a bump in the road that shattered the tube
Old Mar 21, 2006 | 11:19 AM
hcivicdx96's Avatar
hcivicdx96
thanx for the info i aint gettin them ne more i guess ill jsut get sum on the interior.. how would i wire it up to the fuse box.
Old Mar 21, 2006 | 06:14 PM
Provocateur's Avatar
Provocateur
On permanent hiatus
Install them into the trash can.
