Hood Pin Question
I am thinking about getting hood pins to be on the safe side.
Which ones should I get? Link 1 or link 2?
http://www.robearracing.com/pd_sparco_hood_fastener.cfm
http://www.robearracing.com/pd_sparco_hood.cfm
Originally Posted by teg92
all you have to do is drill 1 big hole for the pin and 3 little holes to screw the hood pin to the hood. Its fairly easy
EDIT: Do these look like good hood pins or should I just get the ones in the second link? These are from Ebay:
Originally Posted by westcoaststyle
Get good ones.... like Sparco or something. The cheap ones will eventually rust and sometimes bend.
Originally Posted by dawrenn
I just ordered a set of Sparco hood pins from Robearracing.com they should be here in a week. I just hope I dont fvck up when I am installing them.
Just install them on your upper radiator support. Make sure your hood is the way u want it first before you do anything. Then put some white out on the top of the hood pin holder that sticks out from the upper radiator support and it will mark the hood. Then drill the holes. The Hood pins should also come with directions
Good luck
Good luck
