Wet Sanding
Old Mar 1, 2004 | 07:47 PM
Black2000Si's Avatar
Black2000Si
Default Wet Sanding
HI, i was wondering what kind of sandpaper i need to wet sand a car? is 2000 grit to fine or okay to use? also anyone have experience with using 3m rubbing compound and glaze? thanks
Old Mar 1, 2004 | 08:26 PM
wedley2's Avatar
wedley2
bboy Wesley West
to sand the original paint off the car?
id start wit 320, 2k is way fine...
Old Mar 1, 2004 | 08:33 PM
93HybridCX's Avatar
93HybridCX
Beast from the East
He is talking about wet sanding which you do to remove small scratchs or orange peel.
Ok to answer the question you can you 1500 or 2000 grit paper to wet sand the car. Just make sure you keep the sand paper and the paint surface very wet to prevent scratching/sanding through the clear coat. 3M products are some of the best out so thats what I would use. When you buff the car just make sure you don't keep it on any edges or corners for very long or you will burn through the paint.
Old Mar 2, 2004 | 09:52 AM
JDMunillaFD3S's Avatar
JDMunillaFD3S
i've always used 1500. it seems to work well.
Old Mar 4, 2004 | 07:27 AM
93Nteg's Avatar
93Nteg
1500 is what I use.
Old Mar 4, 2004 | 08:03 AM
93DituneEX's Avatar
93DituneEX
HIDs teh hotness!
Hey could someone do a write up for this. Would be something nice to know how to do ifit gets scratches off.
Old Mar 7, 2004 | 09:54 PM
infamous1se619's Avatar
infamous1se619
http://www.goodspeedmotoring.com/?page=sanding
Old Mar 7, 2004 | 10:25 PM
randomtask77's Avatar
randomtask77
Wanderer
Originally Posted by infamous1se619
Good link. :thumbup:
Old Mar 7, 2004 | 10:34 PM
asiandoood's Avatar
asiandoood
sancho on the sizzide!
when u wetsand...i recommend using a small amount of dishwashing detergent to lubricate the sanding process.
SpeedDriven
Mar 2, 2004 10:22 AM
Wharbone
92+ Civic/EL & Del Sol
14
Aug 30, 2003 08:45 AM
dom93hatch
Aug 20, 2003 08:22 AM
SpeedDriven
May 4, 2003 03:27 PM
TriniSpeed
4
Dec 17, 2002 08:44 PM
